| PEM REPLICA SUZ GSX 2013 | |
+32gef jp ALF Raoul Volfoni phiphi Coyote luc j-c Lemarquis macpepr tidji JackCélaire japy Vuidar Marc COSMIK marechal_23 caffy arnaud ALAIN nini72 baloo la tige Jean Louis dom1135 Flo éJéJ THIERRY67 Dimble rogerboldor franck Titane Pierre STOK51 36 participants |
| Sujet: PEM REPLICA SUZ GSX 2013 1/12/2012, 20:30 | |
| BON VOILA L TOPO CA FAIT PLUS DE DIX ANS QU ON RESSORT DES ANTIQUITES DES FONDS DE GARAGE TOUTES PLUS AUTHENTIQUES LES UNES QUE LES AUTRES LES MACHINES D EPOQUE AVEC MEME LES VRAIS KITS PISTONS EN 998 CC ET LES MOTEURS USINE DE CHEZ MOOOSIEUR YOSHIMURA HIMSELF MAIS C EST PAS QU ON EST AU BOUT DES RESERVES ON VOUS RASSURE MAIS C EST QUE CA PEUT PLUS DURER A FORCE DE RETROGRADER DANS LES CLASSEMENTS DES QUALIFS ON VA FINIR PAR SE FAIRE BOULER D ENTREE AVEC NOS MACHINES ORIGINALES DONC ON A PRIS DES MESURES RADICALES .... DEJA POUR EVITER LES MAUVAISES SURPRISES ON PART SUR DES CHASSIS NEUFS DANS DU TRES BON ACIER LA BOITE A ROULEMENTS DU BRAS OSCILLANT SUR LE TOUR LES BRAS SUR LA FRAISEUSE LE BRAS MAINTENANT SOUDE ET ASSEMBLE ENTIEREMENT CONSTRUITS A LA MAISON AVEC LE SAVOIR FAIRE D UN MOZART DU TIG LES BERCEAUX ASSEMBLES AHHH OUI J AI OUBLIE DE VOUS DIRE ON EN FAIT PAS UN MAIS DEUX ENGINS DE COURSE JUSTE DES TES DE FOURCHE TAILLES DANS LA MASSE HISTOIRE D AVOIR LA GEOMETRIE PARFAITE QUE L ON SOUHAITE PUIS ENSUITE FINI LES ROUES MAGNESIUM PRESTIGIEUSES LES FOURCHES DU MEME METAL A 3 MILLIONS DE DOLLARDS ET LES FREINS FONTE SERIE OR INTROUVABLES ON DONNE DANS LE FACILE A TROUVER ET A MODIFIER ET LE GRAND CLASSIQUE ROUES GSXR 1100 FOURCHE KAWA 1000 R ET FREINS BREMBO P08 NEUFS LES POLY ET SELLE MAISON EVIDEMMENT ET MAINTENANT APRES QUELQUES MOIS DE TRAVAIL ON A UNE PARTIE CYCLE DANS LAQUELLE ON A TOTALLEMENT CONFIANCE ON PEUT METTRE UN MOULBIF A LA HAUTEUR SANS APREHENSION CE QUI SE FAIT DE MIEUX TOUT EN ETANT 100% CONFORME AU REGLEMENT UN TRES BON GSX 1100 A LA SAUCE TITANE LE LIEN CI DESSOUS POUR VOUS RENDRE COMPTE DE LA FEROCITE DES FAUVES https://www.fmsp.net/t10154-les-presque-jumeaux-malefiques ET POUR VOIR UN PEU QUELLE EST NOTRE MARGE DE PROGRESSION AVEC UN MOTEUR "MODERNE" CE SOIR LA GUERRE EST DECLAREE ON L A DELICATEMENT POSE DEDANS ... C EST COMME UN TIGRE FAUT PAS TROP LE BOUSCULER DE PEUR QU IL NE SE REVEILLE EN SURSAUT C EST PAS ENCORE LE BON MOMENT IL EST RENTRE AU DIXIEME DE MM CELA DEMANDE DU DOIGTE ET DE LA PATIENCE ON A MEME DU MEULER UNE PETITE AILETTE DU BAS MOTEUR POUR AIDER C EST VRAIMENT DU SUR MESURE UN JOLI AMORTISSEUR WILBERS NEUF CA PEUT PAS NUIRE MAINTENANT PLACE AUX ECHAPPEMENTS A SUIVRE YVES
| Sujet: Re: PEM REPLICA SUZ GSX 2013 1/12/2012, 20:34 | |
| et donc .... |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 1/12/2012, 23:00 | |
| et donc... ça va ouiner et d'une force ... le moteur étant un peu mahousse, il a fallu jouer d'la fraise pour affiner une ailette du bas carter qui faisait chier ( un sam'di a 19 heures après une journée de boulot !!! nan mais j'te jure !) tout ça passque ça passait pas le berceau inférieur ajusté vous avez dit ? ah oui ... c'était juste après avoir viré le couvre AC, le bouchon de la prise compte tour, le carter inférieur , les bouchons pour le radiateur d'huile, le carter du filtre à huile et même ................... un goujon qui tient la vis du dit carter !!! c'est pas au chausse pied que ça rentre, mais au poil de cul ! Bon... d'un autre coté , c'est pas nouveau ...on a déjà joué à ça Juste que ça sent pas l'échange standard entre les qualif et la mise en grille au programme :montage de l'échappement pour vérifier que "tout" passe et petite séance cosmétique au niveau des platines , axes et visserie pour fixer le moteur ( ça c'est pour Yves pdt les fêtes ) ensuite , on rapatrie chez moi pour le reste ... à suivre |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 1/12/2012, 23:05 | |
| Beau travail, on voit la bête cette année à quelle occasion ? |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 1/12/2012, 23:13 | |
| Ca prend belle tournure cette affaire là !!! C'était vraiment pas la peine que je serre toutes les vis si c'est pour tout démonter de suite ... Ca a vraiment intérêt à être fiable sinon j'en connais un qui va se faire appeler ................. JM |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 00:16 | |
| ah ba zut il est deja tous rayé le cadre joli qd meme tt ca ! |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 08:42 | |
| Juste que ça sent pas l'échange standard entre les qualif et la mise en grille C'est du GSX , pas de démontage avant la fin de l'année prochaine |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 08:57 | |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 09:26 | |
| bon aller , le J-Y qui va nous refaire le coup de la Yosh dans les lignes droites .... n'oublie pas de freiner au BUS STOP ..... très très beau projet . qui fait saliver .................................slurp ... |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 10:01 | |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 10:04 | |
| Donc, tu vas faire Spa .... |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 10:08 | |
| oui, oui Spa c'est tout prévu ailleurs, ça sera selon les dispo de chacun |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 12:56 | |
Nombre de messages : 505 Age : 34 Localisation : Vendée Date d'inscription : 14/10/2012
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 19:36 | |
| Oh la vache, vous m’impressionnez de jours en jours ! Chapeau ! |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 19:54 | |
dom1135
Nombre de messages : 472 Age : 65 Localisation : sud ouest Date d'inscription : 17/12/2010
| Sujet: Re: PEM REPLICA SUZ GSX 2013 2/12/2012, 20:13 | |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 07:51 | |
| Je trouve tout cela bien joli moi aussi, mais un truc me chiffonne, Il me semble que Morena n'a pas fabriqué des chassis mono amorto sur le côté pour Suz, mais cela ressemble fort à du national moto (entre autre un peu copié sur du Pem et pour Kawa). Demandons aux experts de la bibliothèque du Forum pour confirmer, dés fois qu'il y ai eu une aventure oubliée d'avoir été racontée. Mais c'est bien beau et cela donne envie JL |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 08:32 | |
| salut jean louis eh ben si ... c'est vrai que les Pem Suz (les vrais , pas bidouillés,) sont rares et méconnus pour la petite histoire , quand j'ai acheté le cadre modèle ( celui là est une réplique exacte ), je ne me suis pas posé la question... je ne connaissais que des Pem pour Kawa ( de 77 à ...) essentiellement et qq uns (plus recents pour Honda 82 83-- B BONHUIL ) eh hop .. c'est parti pour faire deux répliques ; les berceaux ont été sous-traités chez un gars qui a un cintreuse numérique... au moment de voir avec lui la position exacte des pattes d'ancrage moteur et au moment de voir si on mettait du Z ou du J, je me suis pointé avec deux jeux de carters nus ... nibe , nada ! ça voulait pas ! moment de solitude ... c'est quoi ce truc ??? c'est Yves qui a eu la bonne idée de présenter des carters de GS 1000 2 soupapes ... miracle : pile poil ... j'ai depuis retrouvé une trace d'engagement en endurance d'une telle moto ( F GIBOL je crois, mais faut que je recherche ) avec un GS mais ça peut aussi être une construction NM pour le mien ...?? le GSX , ce n'est pas historique ... c'est une idée d 'Yves encore .. fixations identiques donc on a tenté le coup ... ça passe, mais au dixième ... voila ,voila |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 08:49 | |
| Je me doutais bien qu'une partie de l'histoire moto n'était pas encre toute connue, les sourciers en docs vont bien nous trouver des tofs d'époque ou les anciens pilotes??? qui l'aurait vue avec un GS.
JL |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 09:35 | |
| Il y avait celle là en 1980 comme PEM pour moteur GS 1000. Mais contrairement à ce qui est écrit, le bras oscillant est un Schiltz. JM |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 09:38 | |
| Capacité d'huile 7 litres .... ça fait pas un peu beaucoup ... |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 09:42 | |
| - THIERRY67 a écrit:
- Capacité d'huile 7 litres .... ça fait pas un peu beaucoup ...
Une des innombrables absurdités que les journalistes retranscrivaient. Faut dire que le concepteur de l'engin était un grand joueur de pipeau. JM |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 3/12/2012, 13:09 | |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 27/1/2013, 00:05 | |
| SUITE DES MONTAGES DU MOTEUR DANS LE CADRE DEFINITIFS CETTE FOIS AVEC LES FINITIONS "AVIATION " a+ yves |
| Sujet: Re: PEM REPLICA SUZ GSX 2013 | |
