Sujet: SUZURACE 2011 4/8/2010, 23:01
EHHH WALA C EST REPARTI POUR UN TOUR DE PLUS EN PLUS FORT
2010 VOUS AVEC VU ET ENTENDU CELLE CI SUR LES CIRCUITS
UN TOUT PETIT 998CC YOSHIMURA TRES PRECIEUX DANS UN CADRE PEM D EPOQUE
ENFIN FAUT BIEN SE RAPPELER QU AU DEBUT CELA RESSEMBLAIT A CA ... IL Y A PILE UN AN
ET TOUT LE RESTE HOME MADE ....
ON PASSE LE CAP
CETTE FOIS CI CONSTRUCTION TOTALE DE TENEZ VOUS BIEN 2 MACHINES NEUVES
TOUT CONSTRUIT DE ZERO LES CADRES LES BRAS OSCILLANTS ET LES BERLINGUES
QUAND JE DIS CONTRUITS ON NE PARLE PAS DE BRICOLAGES DE RESTORATIONS OU D ADAPTATIONS C EST TOUT FAITS DANS LES REGLES COMME D AB ET 1000% CONFORMES AU REGLEMENTS LES PLUS TATILLONS
LES GEOMETRIES LES SOLUTIONS TECHNIQUES ET LES BASES MECANIQUES ANTERIEURES A 1980
BON LE POINT DE DEPART CETTE SEMAINE J AI ATTAQUE LE NERF DE LA GUERRE LES BROUZOUFS CA VA ENCORE MIAULER DANS LES BOIS DES ARDENNES MAIS CE COUP CI ON SE RETIENT PLUS ON A PAS DU BERLINGUE HISTORIQUE A PRENDRE GRAND SOIN CAR UNIQUE ET FAISANT PARTIE DU PATRIMOINE MONDIAL DE L HUMANITE MOTOCYCLISTE
ON EST DANS DE LA BASE DU VULGUS PECUM DU TOUT VENANT DU AU POIDS A LA CASSE DU COIN DU A DEBARASSER SOUS PEINE DE FONDERIE DE LA BALADURETTE A LA REFORME DE LA PRIME A LA CASSE DU BORLLOO A RECYCLE
ET GROS ON LUI TAILLE DANS LE VIF SANS AUCUNE RETENUE ON LUI COLLE DES BOURRINS A EN RACOURCIR LES BIELLES ON VA CHERCHER LA LIMITE ET ON SAIT QU ELLE EST TRES TRES LOIN
ON VA SE MARRER ON A GEF EN POINT DE MIRE
SAVACHIER
A+ YVES
Sujet: Re: SUZURACE 2011 4/8/2010, 23:04
Des cadres poutre ?
LE BLOC OPERATOIRE A FONCTIONNE A PLEIN REGIME
VOILA LES CADAVRES J AI COMMENCE A RACLER L OS ..
LE MODELE DU MAITRE A PORTEE DE MAIN POUR PAS S EGARRER DIEU POPY VEILLE SUR SES OUAILLES
ET TOUTES LES PETITES FAIBLESSES CONSTATEES EN COURSE CETTE ANNEE SERONT BIEN SUR CORRIGEES
LE COUVRE CULASSE PAR EXEMPLE PAR UN MODELE A 4 VIS RENFORCE CEUX QUI ETAIENT A SPA M ONT COMPRIS ON VOIT D AILLEURS BIEN LA SOUDURE DE LUC QUI A PARFAITEMENT TENU
A+ YVES
Sujet: Re: SUZURACE 2011 4/8/2010, 23:06
les affaires reprennent
Sujet: re suzurace2011 4/8/2010, 23:08
t'a raison persiste dans les suz jme doute de ce que tu prépare
Sujet: Re: SUZURACE 2011 4/8/2010, 23:29
POUR BROUILLER UN PEU LES PISTES .... CHERCHEZ L INTRU
TROP FASTOCHE
BON ALLER AU PLUME DEMAIN YA MECANIQUE SUITE
A SUIVRE
A+ YVES
Sujet: Re: SUZURACE 2011 4/8/2010, 23:32
olé, olé ça y est , remettez nous ça patron one again, ouane egaine, bissetouflaille
vous deviez un peu vous en douter, nan ? nan ??? vous m'avez cru quand je vous avais annoncé avoir viré les goujons du carter pour nettoyer les filetages ???
à vrai dire, on ne sait pas encore exactement comment ça va se presenter .... ce qui est sur, c'est qu'il y a deux moulbifs en pièce et qu'on va pas les remonter "orig" déjà, pour commencer, les bloc cylindre ne sont pas frappés 1074 ..... mais 1135 ... et c'est pas pour faire l'économie d'un réalésage ....
pour le reste, on vous dira (tout ?) en allant ....
pour les cadres, non, non, c'est pas du poutre.... Maitre braiseur- françois ayant validé le PEM double berceau monoamortisseur latéral,... "un vrai bonheur" ..."y s'passe rien nulle part " "meme dans la foret, vite, c'est les coucougnettes qui manquent, mais pas le cadre qui bronche" .... validé le PEM, donc, eh ben ...... quand tu gagnes, tu r'joues , nan ? on lui a donc fait faire des petits, à l'enfant de Mr MORENA (des jumeaux, tant qu'a faire ...)
les ébauches des berceaux en 25 CD4S sont d'équerre .... Luiggi a pour mission de les finir en copiant l'original
avec les GAZ, on va optimiser un peu tout pour avoir le max de pièces en commun next year, eux et nous serons le meme team, avec exactement les memes bécanes et vraissemblablement des couleurs inversées ça devrait avoir de la gueule un truc comme ça (une des motos est pour eux)
GAAAAAAZZZZZZZZZZZZZZ
Thieryyyyyyyyyyyyyyyyyyyy regarde bien la génèse des machins qui vont ...... t'abeiller dans les oreilles !!!
Sujet: Re: SUZURACE 2011 4/8/2010, 23:38
et les chemises ont été sorties pour bien nettoyer l'alu derrière !!!!! si, si
Sujet: Re: SUZURACE 2011 4/8/2010, 23:41
Bon je vais me coucher, trop forts les rémois et leurs complices
Sujet: Re: SUZURACE 2011 4/8/2010, 23:42
TROP FASTOCHE
A SUIVRE
A+ YVES
J' ai trouvé l' intru: Le pneu a tétines...
Sujet: Re: SUZURACE 2011 5/8/2010, 21:50
TROP FORT FLY
C ETAIT EFFECTIVEMENT LA MEILLEURE REPONSE QUE J ATENDAIS ... LE TRIPLE ETAIT JUSTE LA POUR BROUILLER LES PISTES
A+ YVES
Sujet: Re: SUZURACE 2011 5/8/2010, 21:55
BON SUITE DE L AUTOPSIE DU MONSTRE
LE MAL AVAIT PARFAITEMENT ETE IDENTIFIE EN COURSE A SPA ET ON A BIEN FAIT DE NE PAS INSISTER C EST LE MOINDRE MAL RIEN N EST ABIME SUR CE TRES BEAU MOTEUR
JUSTE UN JOINT DE CULASSE PAS ASSEZ RESISTANT LE PROCHAIN SERA EN CUIVRE CELUI CI A FAIT ENVIRON UNE VINGTAINE D HEURE DE CIRCUIT C ETAIT TROP LUI DEMANDER
UN PETIT SURFACAGE DE CULASSE ET DU BLOC CYLINDRE HISTOIRE DE PARTIR SANS APPREHENSION
CA C EST DU JOINT DE CULASSE PETE
"ALLOOOO GARAGE GAUDIN J ECOUTE "
A+ YVES
Sujet: re suzurace 2011 5/8/2010, 21:56
les PEM c'est bien
copieur
a+ alain
Sujet: Re: SUZURACE 2011 5/8/2010, 22:21
ON COPIE PAS ..... ON PRESERVE LE PATRIMOINE APRES L AVOIR SAUVE DE LA BIFFE C EST TRES DIFFERENT
A+ YVES
Sujet: Re: SUZURACE 2011 5/8/2010, 22:32
ah ben oui il a bien pété ton joint de culasse
ca a du commencé quand elle c est mise a fumer grave par le reniflard
Sujet: Re: SUZURACE 2011 6/8/2010, 00:39
LE PASSAGE DANS LE PUIT DE CHAINE DE DISTRIBUTION FAISAIT QUE CELA FUMAIT MAIS NE CONSOMMAIT PAS D HUILE
ENSUITE CELA NE S EST BIEN SUR PAS ARRANGE .... ENFIN RIEN DE BIEN GRAVE ET FACILEMENT REPARABLE
A+ YVES
Sujet: Re: SUZURACE 2011 6/8/2010, 07:44
EX - CE - LENT
vite la suite .
Sujet: Re: SUZURACE 2011 6/8/2010, 08:38
merci encore du rêve a suivre bon courage pour la suite
Sujet: Re: SUZURACE 2011 6/8/2010, 09:14
bon .... ben c'est pas bien méchant , ça mon petit doigt me dit que l'heure de la retraite n'a pas encore sonné on va finir d'ausculter la merveille ... il y a un petit roulement qui se barre .... ça doit pas être terrible non plus ... berlingue rachoupillé, partie-cycle encore optimisée .... ça sent encore le bonheur, tout ça
ça va ouiner et l'abeille va encore sonoriser le bout droit tiens, je vous en remets un petit coup ..... je ne m'en lasse pas !
Sujet: Re: SUZURACE 2011 6/8/2010, 09:32
ET ENCORE LA ELLE ETAIT EN MODE VALIDATION REMISE EN ROUTE APRES 25 ANS DE SOMMEIL
A SPA C ETAIT ENCORE UN AUTRE NIVEAU DANS LA DESCENTE DES STANDS AVANT LE RAIDILLON J EN AI LES TYMPANS QUI FRETILLENT ENCORE
MEME PAS BESOIN DE LEVER LES YEUX JE SAVAIS QU ELLE ETAIT PASSEE A L OREILLE LA MONTEE EN REGIME CARACTERISTIQUE ET LE MIAULEMENT DE LA PETITE CYLINDREE INCOMPARABLE
ON VA L ENTENDRE A NOUVEAU EN VERSION HYPER LIGHT 1CV/1KG
A+ YVES
Sujet: Re: SUZURACE 2011 6/8/2010, 10:09
Un beau sujet que vous nous préparez là + le fait de monter une structure de 2 machines c'est parfait. + S'instruire en samuzant . Pour le joint de culasse, le Cu dont tu parles, c'est en 3 couches ou en 1 épaisseur ? Je revois encore les english qui posaient un bout de fil de FER sur le joint de culasse(à l'endroit le plus faible) avant de refermer... .
