DESOLE DE LA REPONSE TARDIVE ...
J AI UN MOT D EXCUSE ET QUELQUES TEMOINS ...
ON FAISAIT DU TOURISME RAPIDE EN BELGIQUE
POUR LES JANTES 5 BRANCHES MARTIN
SI CELLE CI SONT EN BON ETAT CE QUI EST LE MIEUX C EST LE MONTAGE TUBELESS
CAR CELLES CI SONT PREVUES POUR
AVEC UN PROFIL DE FOND DE JANTE AUX NORMES ETRO
POUR LA VALVE CE SONT LES ANCIENNES NORMES AU PETIT DIAMETRE
FAITES POUR DES VALVES METALLIQUES EN GENERAL EN ALLIAGE ALUMINIUM
AVEC UN JOINT TORIQUE QU IL FAUT CHANGER A CHAQUE DEMONTAGE DE VALVE
ATTENTION AU REPERCAGE ET MONTAGE DE VALVES CAOUTCHOUC MODERNES
TYPE AUTOMOBILE C EST ASSEZ RISQUE ET "CERTAINS ONT EU DES PROBLEMES"
WALA
APRES SI LA JANTE EST POREUSE DEFORMEE OU MARQUEE SA PLACE EST PLUS AU
MUSEE QUE SUR LA ROUTE
CHACUN JOUE AVEC SA VIE COMME IL L ENTEND
LE MONTAGE D UNE CHAMBRE N EST QU UNE SOLUTION DE DEPANNAGE ....
