IL EST POSSIBLE QUE TU AIE UN POINTEAU OU UN FLOTTEUR QUI COINCE LEGEREMENT
LORS DU PREMIER REMPLISSAGE
TU FRAPPES LEGEREMENT SUR LA CUVE AVEC UN MANCHE DE TOURNEVIS
CELA SUFFIT PARFOIS POUR METTRE TOUT EN PLACE
ENSUITE SI CELA COINCE TU DOIS REDEMONTER LA CUVE ET AUSCULTER CELA DE PRES
SI C EST PASCAL QUI TE L AS FAITE
LE MIEUX EST ENCORE DE LUI PASSER UN COUP DE FIL
ET DE VOIR AVEC LUI
POUR LA MEMBRANE PERCEE
C EST SUR QUE CELA NE POUVAIT PAS FONCTIONNER CORRECTEMENT
POUR LES RAMPES DE CARBU ANCIENNES 3 OU 4 DEMONTAGES NE SONT PAS UNE EXCEPTION
MALHEUREUSEMENT ON EN A TOUS FAIT L EXPERIENCE
IL EST BIEN RARE QUE JE N Y COUPE PAS NON PLUS SUR MON 1000 R SI JE COMPTE BIEN
J AI DU LA REDEMONTER PARTIELLEMENT 5 FOIS ....
AVANT D ETRE SATISFAIT DU REGLAGE
ET ENCORE JE SUIS SUR QUE C EST PERFECTIBLE
FAUT QUE JE CHANGE MON KIT DE ROBINET A DEPRESSION
LA MEMBRANE EST POREUSE ELLE M ENRICHIT LE CYLINDRE N° 3
