SUITE DES OPERATIONS AUJOURD HUI
ENTRE MIDI MEME PAS LE TEMPS DE SE PRENDRE UN MENU AU DRIVE CHEZ MAC DO
NOUS VOILA SUR LE PROBLEME DE L EMBRAYAGE
JE TATE LA POIGNEE ET VLAN ELLE M EXPLOSE DANS LA MAIN
VOILA COMME CELA C EST FAIT
CELA A EVITE A FRANCOIS DE PARTIR EN WEELING APRES LA POUSETTE DANS LA COUR
CELA AURAIT ETE DOMAGE DE JARDINER DANS LE TALUT D EN FACE
C EST PAS ENCORE LA SAISON DE PLANTER LES PETITES FLEURS CHEZ NOUS
DU COUP ON TROUVE UNE POIGNEE DE JE SAIS PAS QUOI DANS LA BOITE A MISERE
ET ZINGUE C EST REPARTI
REGLAGE AU POIL DE LA GARDE
UNE MEGA COURSE AU CABLE ... AU MOINS 2 CM ....SI AVEC CELA L EMBRAYAGE COLLE
J Y COMPRENDS PLUS RIEN
IL FAUT AVOIR DES PALUCHES DE JOUEUR DE PELOTTE BASQUE
MAIS ON MOINS ON VA SAVOIR
LA QUESTION QUI TUE DE FRANCOIS ... "TU CROIS QU ON LUI FAIT UNE PLAQUE "
A MON REGARD INTERLOQUE IL FONCE DANS LA RESERVE REALISER UN SEMBLANT
D IMMATRICULATION LEGALE
C EST VRAI QU ON EST JOUEURS ET D UNE GENERATION ... UN TANTINET REBELLE A L AUTORITE
MAIS ILY A DES LIMITES A PAS DEPASSER
UN SAMEDI APRES MIDI A 17H00 EN VILLE
C EST PLUS DE LA PROVOCATION
C EST DE L INCONSCIENCE
PAS ENVIE DE SE RETROUVER AVEC LA BRELE A LA FOURRIERE ....CELA NOUS METTRAIT
EN RETARD POUR LA SUITE DU PROGRAMME
LA VOICI DONC AFFUBLEE D UN SEMBLANT DE LEGALITE ....
MMMMMERDE ON A OUBLIE LE RETRO
MSIEUR L AGENT PAS FAIT EXPRES ...
UNE BONNE POUSSETTE DANS LA COUR ET CELA PETE AU QUART DE TOUR
JE CHAUFFE GENTIMENT LA MACHINE
PUIS JE MONTE UN PEU LES TOURS ... 7500 8000
ON SENT TOUT DE SUITE QUE LA CA COMMENCE A DONNER DE LA VOIX
A MON AVIS ENTRE 7000 ET 10000 IL DOIT SE PASSER DES TRUCS
QUELQUES MOTARDS EN MACHINES MODERNES ASSEPTISEES ET CATALYSEES
S APPROCHENT INCREDULES DEVANT LES HURLEMENTS DU DEVIL EN FURIE ...
C EST QUOI COMME MOTEUR ... LA VACHE CA TOURNE FORT ....
FRANCOIS ARRIVE EQUIPE POUR L ESSAI ET PART DANS LA CIRCULATION URBAINE DU SAMEDI APRES MIDI SORTIE DE SUPER MARCHE ... ENTRE LES DACIA ET LES CLIO FUEL
AU PREMIER FEU IL SE LOGE EN TETE DE CONVOI ET AU PASSAGE DU VERT C EST
BEAU A EN PLEURER ... LES 3 PREMIERES VITESSES S ENCHAINENT A BON RYTHME
ET LA LIGNEE DE VOITURE A PAS ENCORE FRANCHI LA LARGEUR DU PASSAGE PIETON
QUE FRANCOIS EST DEJA HORS DE VUE ... MAIS PAS D OREILLE
A LA VITESSE RECOMMANDEE ... POUR LE FONCTIONNEMENT DU MOTEUR
PAS VRAIMENT A CELLE INDIQUEE SUR LES PANNEAUX
CELA SONNE FORT ET CLAIR DANS LE LOINTAIN MAIS UNE CHOSE EST SURE ...
IL A PAS CALE
APRES QUELQUES MINUTES D ATTENTE ILS REVIENT LA BANANE DES GRANDS JOURS
SOUS LE CASQUE
BON POUR LE SERVICE
DEPOILAGE COMPLET DE LA BRELE ET ZOU PEINTURE
MAINTENANT FAUT PAS S ENDORMIR SUR LES LAURIERS
IL FAUT USINER UN ALTERNATEUR MAISON ET TOUT UN TAS DE BRICOLES A FINIR
DIABOLOS BEQUILLE FIXATIONS BOBINES ETC...
BIEN ENCORE 15 JOURS DE BOULOT
ENSUITE LES CHOSES SERIEUSES
PASSAGE AU BANC POUR LES REGLAGES MOTEUR CARBURATION TOP
ET VALIDATION FINALE PLEINE CHARGE POUR DECELER LES FUITES D HUILE EVENTUELLES
ON A PAS ENCORE FINI MAIS CELA AVANCE PAS MAL
