| GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ | |
+17zdrag barry 72 FIFI Lemarquis gef luc Grosomoto ALF MOUN chef BOUM 57 Paul Pierre Bernard Jean Louis bruno STOK51 21 participants |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 16/2/2008, 17:08 | |
| POP Y. MORIWAKI & TAMBURINI ... la barre est assurément très très très haute ... ... mais vous m'avez l'air sur la bonne voie |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 16/2/2008, 20:57 | |
| NOUS SOMMES DE MODESTES UTILISATEURS
LES PISTONS ET LES ARBRES POUR L UN LES CARTERS POUR L AUTRE ET LES CADRES POUR LE TROISIEME
LA DIFFICULTE C EST D ETRE DIGNE DE L ASSEMBLAGE ET QUE LA SYNTHESE SOIT FONCTIONNELLE
ON VOUS DONNE DES NOUVELLES BIENTOT
A+ YVES
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 16/2/2008, 23:10 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 16/2/2008, 23:37 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 13:40 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 14:41 | |
| TROP FORT |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 15:28 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 18:17 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 18:22 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 18:55 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 19:59 | |
| c'est trop fort ce montage + + |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 20:09 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 20:49 | |
| C EST EXACTEMENT CELA EN PREVISION POUR LA VERSION HYDRAULIQUE CELA ME TENTE C EST UN VERIN DE NINJA QUI EST MONTE SUR CE MODELE ? J AI DEJA FAIT DE NOMBREUSES VERSIONS MECANIQUES MAIS COMPTE TENU DES MONTAGES DE RESSORTS TRES RENFORCES JE VAIS SANS DOUTE ESSAYER FAUT QUE JE RECUPERE UNE PIECE SAUF POUR LE POLISSAGE C EST PAS TROP MON TRUC A+ YVES |
MOUN
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 21:27 | |
| sympa ce montage |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 21:35 | |
| MERCI MOUN MAIS POUR LA PIECE DE 400 VFF YA DU Y EN AVOIR 3 VENDUES SUR LA FRANCE ENTIERE JE VAIS AVOIR DU MAL A TROUVER FACILEMENT SURTOUT QUE T EN A DEJA PIRATE UN A+ YVES |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 17/2/2008, 22:51 | |
| en fait le probleme c est pas le recepteur mais le support les recepteurs y en a des tonnes qui trainet |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 05:31 | |
| - STOK51 a écrit:
- C EST EXACTEMENT CELA EN PREVISION
A+ YVES sur la photo de base oui c'est un modèle de ninja celui que j'avais en réserve je l'ai déjà filé à un pote en Z1000 qui veut faire la modif |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 08:17 | |
| - STOK51 a écrit:
C EST UN VERIN DE NINJA QUI EST MONTE SUR CE MODELE ?... vous allez encore me dire que je suis une buse , mais ca sert a quoi ? pourquoi un vérin 'hydraulique arrive ici |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 09:39 | |
| POUR REMPLACER LA RAMPE HELICOIDALE ACTIONNEE PAR LE CABLE D EMBRAYAGE TRADITIONNEL SUR LES MOTOS DES ANNEES 70 ON REMPLACE CELLE CI PAR UN VERIN HYDRAULIQUE COMME C EST MAINTENANT LE CAS SUR 90% DES MOTOS MODERNES CES PREMIERS MONTAGES ONT ETES REALISES CHEZ KAWA SUR LA NINJA EN 85 VISIBLE AU PREMIER COUP D OEUIL LES MOTOS QUI POSSEDENT UN MAITRE CYLINDRE HYDRAULIQUE AU GUIDON A GAUCHE BIEN SUR EN SONT EQUIPES CELA PERMET D AVOIR UNE COMMANDE TRES SOUPLE MEME DANS LE CAS D UNE UTILISATION DE RESSORTS D EMBRAYAGES RACING TRES DURS NECESSAIRES POUR PASSER LA PUISSANCE DES MOTEURS PREPARES SANS PATINER WALA A+ YVES |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 09:44 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 12:39 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 14:04 | |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 18/2/2008, 16:39 | |
| nan plus que ca , mais j' y vais pas trop mon embrayage il aime pas je sais ou trouver des ressort remforceé en plus ... et des disques neufs .... |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ 23/2/2008, 18:14 | |
| SUITE PETITE FANTAISIE DE 63 GRAMMES ALLEZ UN PETIT REGRET JE TROUVE CELA DISCRET ET SURTOUT .....MODESTE RESTE PLUS QUE LA COULEUR AU CHOIX BRUT D USINAGE COULEUR ALU DISCRET LOGO NOIR CLASSIC OU ROUGE RACING A+ YVES |
| Sujet: Re: GAAAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZ | |
