Je prends mon bâton de pèlerin et je part a la recherche...
http://www.knfilters.com/search/appsearch.aspx
Puis:
http://www.knfilters.com/search/univ2.aspx?ID=S0019
Critère de recherche: (dont je suis a peu près certain)
F - Flange Inside Diameter = 54 mm
SA - Base Outside Width = 76 mm (l'espacement entre la rampe de Ninja et RX étant les mêmes)
Info Dynojet:K&N filter #RC-0982 pour 1987-2009 Kawasaki EX500 1987-2010 Kawasaki EX500 & 1991-2006 EN500 ==> L = 70 mm
RC-0981, RC-0982,RC-0983,RC-0984)K&N filters #
RC-1824 pour 1982-83 Kawasaki GPZ550 ==> F = 51 mm
K&N filters #RC-2814 pour 1984-85 Kawasaki GPZ550 (
RC-2810, RC-2814, RC-2890)
K&N filters #
RC-2814 pour 1984-86 Kawasaki ZX900
K&N Filter # RU-2852 pour 1986-87 Kawasaki ZX1000 Ninja
Part
RU-2852 (
faut que je vérifie si ça rentre dans le cadre du Ninja )
Product Style: Dual Flange Oval Tapered Universal Air Filter
Base Outside Length: 6 in (152 mm)
Base Outside Width: 4 in (102 mm)
Flange Center to Center: 2.938 in (75 mm)
Flange Inside Diameter: 2.125 in (54 mm)
Flange Length: 0.625 in (16 mm)
Flange Type: Centered
Height: 4 in (102 mm)
Top Outside Length:
4.5 in (114 mm)Top Outside Width:
3.75 in (95 mm)Top Style: Rubber
Top Material/Finish: None
Filter Material: Cotton Gauze
Flanges: 2
Part
RC-2814 &
RC-2810 Product Style: Oval Tapered Universal Air Filter
Base Outside Length: 4 in (102 mm)
Base Outside Width: 3 in (76 mm)
Flange Offset: 0.438 in (11 mm)
Flange Type: Offset
Top Outside Length:
3 in (76 mm)Top Outside Width:
2 in (51 mm)Top Style: Metal
Top Material/Finish: Chrome
Footnote 1: Offset is vertical
Part
RU-2810 Product Style: Oval Tapered Universal Air Filter
Flange Type: Offset
Top Outside Length:
3.5 in (89 mm)Top Outside Width:
2.5 in (64 mm)Top Style: Rubber
Filter Re-Oiling Amount: 0.39 oz (12 ml)
Flanges: 1
Inner Wire: No
Part
RC-2890 Product Specifications
Flange Type: Offset
Top Outside Length: 3 in (76 mm)
Top Outside Width: 2 in (51 mm)
Top Style: Metal
Flanges: 1
Inner Wire: No
Part
RU-2750 &
RU-2754 Product Specifications
Flange Type: Offset
Height:
5 in (127 mm) Top Outside Length:
Filter Re-Oiling Amount: 0.49 oz (15 ml)
Flanges: 1
Inner Wire: No
Part RC-2900 Product Specifications
Flange Type: Offset
Top Style: Metal
Flanges: 1
Footnote 1: Offset is vertical and to the right
Inner Wire: No
