VOILA LES EXEMPLES LES PLUS COURRANTS DES PROBLEMES QUE L ON TROUVE SUR LES CULASSES KAWA
JE REMERCIE CEUX QUI MON DONNE CES PIECES POUR VOUS EN FAIRE PROFITER
J AI DEMONTES 2 CULASSES HIER VOILA LES RESULTATS
TOUTES ONT DES FILETAGES DE PALIERS D ARBRES A CAMES ARRACHES
ET QUELQUES AUTRES BRICOLES A REVOIR AVANT REMONTAGE
LE PIRE PROBLEME C EST LA REPARATION
PAR DES BRICOLEURS PAS OUTILLES
LA PREMIERE MAUVAISE METHODE C EST REPERCER AVEC LE MORCEAU DE VIS CASSE DEDANS
CELA DONNE CE RESULTAT
ET IL FAUT DONC RETIRER LE MORCEAU DE VIS CASSE
AVANT DE RESSOUDER
OU C EST PERCE DROIT MAIS TROP PROFOND PASSE A TRAVERS AUSSI
ENSUITE IL Y A L ERREUR DE SENS DE ROTATION DE L ARBRE A CAME
QUAND L OUTIL KAWA EST EN PLACE .... CELA DONNE CE RESULTAT
DONC 2 CULASSES SUR LA TABLE D OPERATION AVANT REMONTAGE
A SUIVRE
