-27%
-27% sur la machine à café Expresso Delonghi La Specialista Arte
399.99 € 549.99 €
 HARRIS MAGNUM 1
Vuidar Marc
Coyote
nico636
ultraviolet91
baba41
31 participants
HARRIS MAGNUM 1 - Page 2 Empty
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 00:42
je vois que certain on épluché a la loupe les motos du team glam Cool !!!
système  d'embrayage type mv agusta albino
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 09:02
Belle piece   albino   albino
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 09:15
James vend tout : Si tu a oublié de demander au Père Noël, voici la liste des courses
Guys
Its time to move on.
Team Glam P+M endurance Kawasaki’s for sale as a job lot as follows –
Two bikes both the same, All parts are interchangeable.
These bikes have been developed over the last 15 years as race bikes and 8 years as endurance bikes.
They are ready to race and win.
They have won races and championships all over Europe with many different team mates partnering me.
Chassis
Astralite wheels, fully riveted and flanged black anodised.
300mm discs on billet anodised special carriers
Light weight hubs
Captive spacers
Cush drive hubs
38mm cartridge forks machined bottoms all by MCT Suspension.
Billet fork brace with quick release front mudguard.
Alloy yolks
Alloy billet handle bars
DID Gold X ring Enduro race chain
Renthal Sprockets
Talon light weight front sprocket
Aluminium front fairing bracket and screen brace
Under slung steering damper
AP calipers front and rear,AP master cylinder HH 95 pads
Braded lines
Falcon alloy rear shocks overhauled and revalved by Falcon
Alloy rear sets
Crash bungs
Quick release rear wheel
Oversize bobbins.
Twin head light fairing with quick release fittings.
Harris belly pan
Quick release seat unit fully upholstered.
All fasteners titanium or aluminium.
Zeta unbreakable clutch perch with extended lever and single hand operation for clutch adjustment.
Boyer ignition with built in rev limiter
NGK plug caps and new leads
NGK B9EGV plugs
Billet alternator housing with high output alternator.
Spa Digital Stepper dial rev counter with built in 3 stage programmable shift lights and needle.
Serk oil cooler with braided lines and ali fittings.
Dry break oil filler and filling syringe.
35mm CR Keihins both in mint condition, push pull throttles.
New fuel lines and filters.
Alloy 24 litre tanks.
Billet clutch lifters
Tool steel clutch push rods to all engines.
P+M exhaust headers with sprung loaded removable can.
4 Engines in total , all ready to race. 2 in the bikes 2 Spares on wheeled engine cradles
1 Engine as follows
140 bhp +
Z900 bottom end with machined cases to take unitrac top end with hyvo chain.
1260cc Omega Slipper Pistons 12.6:1 CR PTFE skirts and gold nitride rings
Falicon Super Crank lightened, balanced with Falicon Knife rods.
Unitrac head profiled to match pistons
Race flowed with shim under Arrow buckets
New flowed inlet rubbers.
Kent full race cams and slotted sprockets
Unitrac gear box with undercut dogs by Diptune
Unitrac clutch,ebc springs and plates
Currently right foot shift, can be either, parts to swap supplied.
3 avaliable as follows
All approx 130 bhp on PDQ Dyno.
1170cc Wiseco Pistons 11.5:1 CR
Unitrac Crank all rebuilt by Dave Branch or Ray Debben some welded.
Unitrac cams
Other Parts
Harris stands front and rear to both bikes
2 dump fillers with stands
1 oil filler
Spare day race fairing with no lights
Spare new night fairing
Spare new night seat
High level pit tower with rain cover, internal seat, lcd monitor and pit lane connections
Internally illuminated pit signal light box with all numbers
Spares
Spare set of wheels, spacers, discs and sprockets – straight swop.
Spare billet alternator housing and alternator and rotor and crash protection.
Ignition housings
Ignition rotors
Coils
Handle bars
Levers
Footrests
Crash bungs
Throttle and cables
Clutch cables
Seals, gaskets, brake pads
Tyres
Many different shock springs
Loads of boxes of other stuff I cannot remember, but everything you need for several seasons racing.
These could be short circuit bikes as well and I have a spare short circuit race tank that I will throw in that is ready to use with filler taps etc.
£28,000 the lot or may split
Email me if you need more info or call me
James
07760174498
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 09:50
From Australia, si, si, je vous assure  Very Happy
HARRIS MAGNUM 1 - Page 2 P1130710
HARRIS MAGNUM 1 - Page 2 P1130711
Sympa le casse noix racing  Very Happy
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 10:23
Very Happy  Oui, Philippe,  j'ai eu la liste avec des photos (comme toi je suppose) et Globalement le prix demandé par le GLAM n'est pas élevé, en regard du matos et de sa qualité et de plus c'est ready to race
nico636
nico636
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 10:56
C'est pour enlever les noyaux des cerises?   Very Happy
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 10:57
Super Pierre , de très belles pièces pour une bécane vintage très originale , impatient de voir la suite . albino
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime27/12/2013, 20:11
albino  jolie piece albino
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime30/12/2013, 10:34
alors comme cela Pierre, tu commences a faire dans la haute couture....il va falloir bientôt te vouvoyer Very Happy
dejà que tu as de belles lettres de noblesse avec ton 1000R.
RV
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime30/12/2013, 10:42
 Pour nico636 , le système d'embrayage est actionné d'origine par une vis en acier dans une noix en plastique hélicoïdale et cette pièce est un levier direct qui actionne la tige qui passe dans l'arbre de boite .  casse
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 13:39
De retour d'époxy... banana1   Vernis transparent
HARRIS MAGNUM 1 - Page 2 P1030411
HARRIS MAGNUM 1 - Page 2 P1030412
HARRIS MAGNUM 1 - Page 2 P1030413
HARRIS MAGNUM 1 - Page 2 P1030414
HARRIS MAGNUM 1 - Page 2 P1030415
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 13:45
superbe  albino  albino  albino
bon , maintenant , faudra attendre que la mienne soit finie ... casse  casse  casse
mais ça te donneras des idées .. casse
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 15:27
les soudures jaunes apparentes c est pas tres beau
bon apres les gouts et les couleurs  Very Happy
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 18:19
C'est splendide ce cadre vernis.
Quand je serais grand ma Harris aura droit au même traitement.
Mais peut-être avec un vernis plus satiné.
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 19:56
Bravo  Pierre  albino   albino
j' aime bien les brasures apparentes sur le cadre sablé vernis
tu fais le rodage début mai à Magny cours?
Encore une belle moto spéciale
à+
j-claude
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 20:43
Magnifique!!! bounce  bounce  bounce  aime  aime  aime
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 21:03
Fallait oser  bounce  bounce  bounce  bounce
Au moins elle seras vite repéré  albino
Japy
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime7/2/2014, 23:16
Bravo. J aime l idee d une machine non peinte. Tous les materiaux visibles ! A reflechir  w01
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 08:55
A propos si quelqu'un connait un peintre qui manie les peintures "made in USA"  proche Paname...pas à un prix élyséen
MERCI !
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 09:58
Bonjour Pierre
c'est quoi " peintre qui manie les peintures "made in USA"" ??????
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 13:22
Peinture aux Humburgers  casse  casse  casse
nico636
nico636
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 14:22
Salut, beau cadre, cela fait "usine",
j'aimerai bien savoir sur quel modèle tu prends exemple, as- tu des photos d'une martin déjà existante pour avoir une idée du projet?
nico636
nico636
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 14:24
excuses moi je voulais dire 'harris' et non 'martin'
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 18:13
Le cadre avec brasures apparentes, je l'ai vu sur un Harris F1 du TT classic, sinon, je ne copierai aucune moto ayant roulé ou roulante
MessageSujet: Re: HARRIS MAGNUM 1   HARRIS MAGNUM 1 - Page 2 Icon_minitime8/2/2014, 20:09
superbe machine albino pour la peinture,Jean Eric Tallemet à Chatillon(92).ne fait que de la moto et a une superbe collection de vieille bécanes année 70.il peut te faire une peinture style 70 ou le drapeau us sur ton réservoir Very Happy  sinon atelier Carmouche à st Ouen(93).
A+ gilles
HARRIS MAGNUM 1
» HARRIS MAGNUM 1
» suzuki harris magnum
» HARRIS H2
» HARRIS sauce Titane
» HARRIS F1 KAWA
