LE FIL ROUGE AVEC .....
PLUS SERRIEUSEMENT UNE DYNAMO SORT DU COURRANT CONTINU .... QUI PEUT DONC RECHARCHER UNE BATTERIE DIRECTEMENT
VIA UN REGULATEUR A LAME QUI LIMITE LA TENSION
ATTENTION CERTAINS TRACTEURS SONT EN 6V D AUTRE EN 12V OU MEME 24 V
UN ALTERNATEUR AUTOMOBILE SORT DU COURRANT ALTERNATIF QUI DOIT ETRE REDRESSE AVANT D ETRE REGULE POUR EVITER DE FAIRE BOUILLIR LA BATTERIE
1/ VERIFIER QUE LA TENSION EST CORRECTE 6V POUR BATTERIE 6V ETC...
2/VERIFIER SI L ALTERNATEUR EST EQUIPE D UN PONT REDRESSEUR INTERNE ... DANS CE CAS IL SORT DU COURRANT CONTINU
3/ ENSUITE CONSERVER LE REGULATEUR DU TRACTEUR SI IL EST ENCORE EN ETAT OU EN PRENDRE UN SUR L AUTOMOBILE DONNEUSE
4/ RACCORDER AU + BATTERIE LE + SORTIE DE REGULATEUR
ET LE - A UNE MASSE AVEC DES FILS DE FORTE SECTION 6MM2 EST SOUVENT UN MINIMUM
DERNIERE CHOSE LES MOTEURS DE TRACTEURS TOURNENT TRES LENTEMENT PAR RAPPORT A UNE AUTOMOBILE
1500 VOIRE 2000 TR/MIN EN FONCTIONNEMENT
ON EST SOUVENT OBLIGES DE MODIFIER LES DIAMETRES DES POULIES POUR QUE CELA CHARGE CORRECTEMENT
ET QUE L ALTERNATEUR TOURNE ASSEZ VITE
