Le Deal du moment : -28%
229.99 €
 DISTRI GPZX KEKE
DISTRI GPZX KEKE Empty
MessageSujet: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 11:52
ALORS T AS TROUVE QUOI DANS CE FAMEUX MOTEUR DONT LES TENDEURS DE CHAINE DE DISTRIBUTION NE FONCTIONNAIENT PAS CORRECTEMENT ?
MODELE DE TENDEUR SPECIFIQUE AU GPZX ????OU AUTRE CHOSE ...
CURRIEUX DE SAVOIR QUEL ETAIT LE PROBLEME ET ENCORE MIEUX LA SOLUTION TROUVEE ...albino albino albino
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 11:56
Pour l'instant on attends, Didier attend d'autre solutions/moteurs.
Pas 36 solutions de toute façon, après tout avoir repris je suppose que la chaine n'est pas la bonne !! jai cru voir deux ref de chaine avec des longueures différentes ...........
A vérifier bien evidement
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 11:58
HEAVY DUTY CAM CHAINS
DISTRI GPZX KEKE Chain
Extra heavy duty cam chains are recommended to help eliminate chain breakage which can result in extensive engine damage. Tsubaki is the only true high performance cam chain available. The Tsubaki engineers have worked with top race mechanics world wide to produce the only cam chains that will stand up to the rigorous demands of high performance race machines. These same chains are equally at home in the stock street bike, affording the owner the added protection of a high performance chain at a price less than stock factory replacement chains.
BSO5MHx122
KZ900 / 1000 thru '80 with 30T sprockets
$47.37
BSO5MHx124
KZ900 / 1000 thru '80 with 32T sprockets (Mark 2)
48.01
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 11:59
TRES CONNU SUR LES CHAINES DE Z 1000 A ROULEAU
LES Z 1000 MKII ET ST EN PARTICULIER AYANT UNE DENT DE PLUS AU VILO ET DONC 2 DE PLUS AUX AAC LA CHAINE EST FORCEMENT PLUS LONGUE
PAR CONTRE JAMAIS ENTENDU PARLER DE CELA SUR LES MOTEURS J OU GPZ MAIS JE LES CONNAIS MOINS BIEN ...
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 12:00
bah pour qu'il y ai environ 2 cm de plus je ne vois pas beaucoup d'autre solution !!!!
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 12:02
BSO5MHx122
$47.37
BSO5MHx124
48.01
EXACTEMENT CE QUE JE TE DISAIS EN MEME TEMPS MAIS TU EST SUR DU Z 1000 AVANT 80 AVEC CHAINE A ROULEAUX
SUR TA MACHINE TU PARLAIS DE GPZX OU 1000 J CE SONT DES CHAINES SILENCIEUSES HIWO SUR CES MOTEURS ....
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 12:05
exact, autant pour moi !!! bom bom bom
ceci étant je ne vois pas d'autre explication !!
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 12:11
POUR TANT IL Y EN A BIEN UNE w01
CAR LA MECANIQUE OBEIT A DES LOIS CARTESIENNE
ET LA REPONSE DOIT ETRE TROUVEE PHYSIQUEMENT
RIEN DE MAGIQUE OU DE DIVINATOIRE DANS TOUT CELA:D Very Happy Very Happy Very Happy
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 12:15
moi j ai verifie les tendeurs et c est les memes sur le j et sur le zx
et de visu en plus
a part la peinture noire sur le zx
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 12:20
faut arrèter les conneries !!!
y'a le vilo, les act, le patin avant et celui de derrière avec le tendeur.
La chaine fait le tour de tout ça.
Tout est à sa place et y'a 2 cm de jeu au tendeur !!!
en plus elle était monté comme ça avant !!
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 14:28
T AS RAISON FAUT ARRETER LES CONNERIES
JE VOIS PLUS QUE L EAU BENITE rabbit
OU EGORGER UN POULET monkey
casse casse casse casse
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 14:35
Very Happy Very Happy Very Happy w01 et encore !!!
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 17:17
un coup de chirurgie serait necessaire ou alors ta chaine elle a 100000km
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 17:24
non, elle est à 1mm de la cote maxi !!! donc mème si pas bonne ...........
et pis mème usée ........... 2 cm !!!!!
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 17:43
ben alors je vois pas
s il y a les trois patins et le bon tendeur c est qu il y a autre chose
compte les maillons
2 tours de vilo et t es fixe
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 17:46
compte les maillons
c'est ce que j'ai dis à didier mais il flemarde Very Happy Very Happy Very Happy
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 18:24
compte les maillons
L A D AUTRES CHOSES EN TETE ...Very Happy Very Happy Very Happy
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 19:09
bon ben y a qu a attendre
MessageSujet: Re: DISTRI GPZX KEKE   DISTRI GPZX KEKE Icon_minitime18/5/2007, 22:15
je viens de me tapper une douzaine de modeles chez buykawa part list et c est toujours le meme tendeur et la meme chaine du 1000j au 1100zx
DISTRI GPZX KEKE
» Une Honda pas comme les autres????
» distri?
» TENDEUR DE CHAINE DE DISTRIB
» calage distri RX/ninja
» CHaine distri, questions ...
