HELLO ROY
THE PROBLEM WITH PEMDA FRAMES IS THAT MR MORENA DOESN'T DO THE SAME FRAME 2 TIMES IDENTICALY
HE BUILT SEVERAL FRAMES TO A LARGE NUMBER OF TEAM IN THE 70'S and 80'S
FOR EACH TEAM HE EXPRIMENT NEW SOLUTIONS AND CHANGE THE GEOMETRY TO THE PILOTS DESIRES
I SEE AT THE DEPARTURE OF THE BOL D OR OR SPA MORE THAN 15 BIKES WITH MORENA FRAMES
A FAMOUS JOKE SAYS THAT MR MORENA IS THE ONLY FRAME BUILDER WITCH IS ABLE TO ASSEMBLE IT ON A KITCHEN TABLE ON WEDNESDAY
AND WIN THE RACE ON SUNDAY
IF YOU WANT TO HAVE SOME REALY ACCURATE INFORMATIONS
YOU HAVE TO GIVE US A PICTURE OF THE MODEL OF YOUR CHOICE
ONLY AFTER IT S POSSIBLE TO ANSWER YOUR QUESTIONS
THANKS
- rt7347 a écrit:
- questions time
1 what year did the PEMDA frame fit the 80mm adjustable head stock?
2 what was the diameter of the front frame tubes 28 or 32mm?
3 aluminum swing arm did PEMDA fit one, or was it fitted privately?
4 When did PEMDA stop making frames?
5 which is the most popular engine to fit a PEMDA Kawasaki, Suzuki Honda?
6 the small head stock what is the diameter is it 60mm?
7 what legnth is the central rear shockabsorber?
thanks
Roy
