EFFECTIVEMENT
L UTILISATION DES ROUES MAGNESIUM FAIT UNE DIFFERENCE MONUMENTALE PAR RAPPORT A DES ROUES STANDARD
LE MOMENT D INERTIE DE LA ROUE AVANT EST CONSIDERABLEMENT MODIFIE ET LA VIVACITE DU TRAIN AVANT EST
SANS COMPARAISON SUR LES BIMOTA EQUIPEES DE TECNOMAGNESIO C EST PARTICULIEREMENT EVIDENT
LE FREINAGE LUI AUSSI S EN TROUVE BEAUCOUP PLUS EFFICACE LA FOURCHE TRAVAILLANT MIEUX
ATTENTION TOUT DE MEME UN TRAIN AVANT EXTREMEMENT PERFORMANT ET LEGER AVEC UN CADRE BIEN RIGIDE
PEUT ENTRAINER DES GUIDONNAGES SUR LES DELESTAGES DE ROUE AVANT A GRANDE VITESSE
C EST PAS DANGEREUX MAIS UN PEU DEROUTANT UN BON AMORTISSEUR DE DIRECTION PEUT ETRE ENVISAGE ...
C ETAIT PARTICULIEREMENT LE CAS SUR LES 500 2T DE GRANDS PRIX DES ANNEES 90 AVEC LES ROUES AVANT DE 16
DE MEME POUR LA ROUE ARRIERE LA MISE EN ROTATION DE LA ROUE EST BIEN MEILLEURE DANS LES ACCELLERATIONS
ET LA REACTION DE LA SUSPENSION AUSSI VU LES POIDS NON SUSPENDUS
LA TAILLE DE LA GOMME DE LA ROUE ARRIERE NE T APPORTE RIEN EFFECTIVEMENT TU PERD UNE GRANDE PARTIE DE LA VELOCITE DE LA
MOTO HYPER LEGERE
CE QUI EST VALABLE POUR UNE MACHINE DE 200 KG NE L EST PAS POUR UNE MACHINE EN DESSOUS DE 150 KG
CE SERAIT MEME CONTRE PRODUCTIF LES 2 TEMPS N AYANT QUE TRES PEU DE COUPLE LE PNEU NE CHAUFFE PAS OU TRES MAL
ET IL EST IMPOSSIBLE DE LE MAINTENIR A TEMPERATURE
UNE TAILLE TRES INFERIEURE SERA SANS DOUTE BEAUCOUP PLUS PERFORMANTE POIDS MANABILITE AGILITE
BIEN VERIFIER AUSSI LES INDICES DE CHARGES DES PNEUX
TU AS TOUT A Y GAGNER
SANS COMPTER QUE LA DIFFERENCE DE PROFIL ENTRE LA LARGEUR AVANT ET ARRIERE TE FAIT TRAVAILLER LA GEOMETRIE
LORS DE LA PRISE D ANGLE ET GENERE DES BRAQUAGES INDUITS
A MOINS DE SOIGNER LA DERIVE DE L ARRIERE A LA KENNY ROBERTS ...MAIS LA YA DU METIER
ET C EST PAS A LA PORTEE DU PREMIER PILOTE VENU
