L ECROU DE PIGNON DE SORTIE DE BOITE SE DEMONTE A LA CLE A CHOC ...
C EST BEAUCOUP MIEUX ET SANS FORCER
CELA EVITE DE FLINGUER LES RAYONS DES ROUES
OU LES PIGNONS DE BOITE DE VITESSE
POUR LA VIEILLE CHAINE PAS DE PITIE UN COUP DE MEULEUSE ET ELLE EST AU TAS
JUSTE UNE CHOSE NE PAS LA JETER IMMEDIATEMENT ... CONTROLER LE NOMBRE DE MAILLONS PAR RAPPORT A LA NEUVE ...
J AI DEJA VU RIVETER UN CHAINE TROP COURTE OU TROP LONGUE
POUR LE RIVETAGE IL EST RECOMMANDE D UTILISER LE VRAI MATOS DE PRO
LE TOP C EST CELUI CI HORS CONCOURS WHALE CUTE 250€ ENVIRON MAIS J AI JAMAIS VU MIEUX
C EST TROP DANGEREUX SI C EST MAL FAIT
SURTOUT QUAND ON EST DEBUTANT
SOIT C EST PAS ASSEZ ET C EST TRES RISQUE
SOIT C EST TROP ET LE MAILLON EST BRIDE
APRES ON PEUT UTILISER CELA ... MAIS IL FAUT AVOIR 4 MAINS ET PAS 3 MAINS GAUCHES
SINON ON A VITE LES DOIGTS PALMES SI LE COPAIN EST PAS PRECIS DANS LE COUP DE MARTEAU
DANS LES 25€
ENFIN QUAND ON S APELLE
ROGERBOLDOR ET QUE L ON FAIT CELA DEPUIS ... QUELQUES ANNEES ET QU ON EN A FAIT DE CENTAINES
AVEC UNE MASSETTE ET UN MARTEAU RIVOIR EN 4 COUPS PRECIS C EST FAIT
ET AVEC SEULEMENT 2 MAINS
L ARTISANAT C EST ....TOUJOURS SUR LE METIER .....
