SI TU MONTES UN BON ROBINET HY FLOW SANS DEPRESSION EN LIEU ET PLACE DE CELUI DU 1000 R
PAS DE PROBLEME CELA FONCTIONNE
SI TU AS LE PETIT ROBICO RIKIKI DE 1000 KAWA D ORIGINE A DEPRESSION ...
C EST SOUVENT TROP LIMITE EN BOUT DE LIGNE DROITE
POUR LES 2 ROBINETS C EST EN COUSE POUR EVITER D AVOIR UN SOUCIS TU DOUBLES LES ALIMENTATIONS
EN CAS DE BRICOLE QUI VIENT COLMATER UNE ARRIVEE
ET AVEC DES CARBU EN 37 C EST TRES GOURMAND ...
ENFIN AVEC UN ROBINET DE CHAQUE COTE LORS DES TRANSFERTS D ESSENCE RESERVOIR VIDE
CELA PEUT EVITER DE POUSSER SUR LE DERNIER DEMI TOUR
