Le Deal du moment : -17%
249 €
 rotor +4deg
9 participants
rotor +4deg - Page 2 Empty
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 11:50
EN CLAIR CE QUE TU PEUX OBTENIR ... TOUT AUTRE PARAMETRE NON CHANGES
C EST ASSEZ PEU DE RISQUES AU DEMARRAGE
BIEN QUE LE RAPPORT VOLUMETRIQUE DU 900 SOIT UN PEU PLUS ELEVE QUE LE 750
11/1 CONTRE 10.5/1
ET EVIDEMMENT SA CYLINDREE SUPERIEURE
IL EST JUSTE POSSIBLE QU UN REGIME DE RALENTI TRES BAS SOIT PLUS DIFFICILE A OBTENIR
ET AVOIR UN MOTEUR QUI COGNE UN PEU PLUS
AU AUGMENTANT TRES LEGEREMENT VERS 1200 TR/MIN POUR UN MOTEUR NEUF COMPRIMANT PARFAITEMENT
SUR UN MOTEUR UN PEU KILOMETRE AVEC DES COMPRESSIONS PAS A 100% IL EST
PROBABLE QUE TU NE VOIE PAS LA DIFFERENCE ....
ENSUITE LA MOTEUR VA ETRE PLUS TYPE VERS LES HAUTS REGIMES AU DELA DE 7000 TR/MIN
C EST PROBABLE
ET A MI REGIME IL EST AUSSI POSSIBLE QUE TU VOIE APPARAITRE UN TROU
AVEC LA SENSATION D UN MOTEUR PLUS CREUX
SI CES REGIMES NE SONT PAS CEUX QUE TU UTILISES
C EST PARFAIT SUR CIRCUIT RAPIDE PAR EXEMPLE
MAIS DES FOIS GENANT SUR LES RELANCES SUR CIRCUIT AVEC BEAUCOUP DE MORCEAU LENTS
PAR CONTRE SUR ROUTE SI C EST PILE DANS LE REGIME DE CROISIERE STYLE 90/100 OU 130/140
CELA PEUT ETRE ASSEZ DESAGREABLE A VITESSE STABILISEE
ET OBLIGE A RENTRER UNE VITESSE ET ROULER A UN REGIME MOTEUR SUPERIEUR
C EST PAS INTERESSANT NI POUR LE BRUIT NI POUR LA CONSOMATION
VOILA ON TOUCHE AU COEUR DU PROBLEME
C EST PAS MIEUX C EST DIFFERENT
A VOIR SI CE DIFFERENT T APPORTE CE QUE TU CHERCHES ... rotor +4deg - Page 2 615257 rotor +4deg - Page 2 615257 rotor +4deg - Page 2 615257 rotor +4deg - Page 2 615257
ENSUITE UN PASSAGE AU BANC VA TE DONNER LE PROFIL DE LA COURBE DE PUISSANCE
IL EST TRES PEU PROBABLE QUE TU GAGNES EN PUISSANCE PURE JUSTE AVEC CETTE MODIFICATION D AVANCE
TU VAS JUSTE MODIFIER LE PROFIL DE LA COURBE
A TOI DE VOIR SI C EST CELA QUI T INTERESSE POUR TON UTILISATION
L ESSAI COMPARATIF SUR LA MOTO DANS LES CONDITIONS D UTILISATION QUE TU SOUHAITES EST A MON AVIS LA MEILLEURE INFORMATION
UN PASSAGE AU BANC VA TE DONNER DES VALEURS COMPARATIVES INTERSSANTES POUR LES AUTRES REGLAGES ET EN TOUT PREMIER LIEU LA VARIATION DE TA RICHESSE DE CARBURATION
A TOUS LES REGIMES ... ET C EST TOUJOURS LA QUE LES GAINS REELS TRES IMPORTANTS SE FONT
MAIS ON EST TOUT A FAIT SORTI DE LA STRICTE MODIFICATION DE 4° DE L AVANCE A L ALLUMAGE
ATTENTION TOUT DE MEME ON NE FAIT PAS VARIER INPUNEMENT ET INDEFINIMENT
LES AVANCES A L ALLUMAGE
CERTAINS MOTEURS SONT TRES SENSIBLES A CE GENRE DE PARAMETRE
ET L ON CASSE DES BIELLES ET DES VILO ....
LE MOTEUR ETANT BEAUCOUP TROP CHARGE SOUVENT CONJUGUE A DES TROP GROS TAUX DE COMPRESSION
LE PREPARATION D UN MOTEUR ETANT TOUJOURS UN AFFAIRE DE COMPROMIS rotor +4deg - Page 2 276328
ET D EVOLUTION ... RAISONNABLE rotor +4deg - Page 2 626681
ME PAS OUBLIER NON PLUS QUE
L IMPROVISATION ET L EXPERIMENTATION NE SONT ABSOLUMENT PAS COMPATIBLES
AVEC LES PETITS BUDGETS
AU RISQUE DE CRUELLES DESILLUSIONS rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 11:56
je vais demander le num de Roger pour avoir un cours je crois albino
Merci à tous en tout cas Merci
sur un forum Anglais, après montage du +4deg les utilisateurs parlent surtout d'un ralenti plus stable, plus propre...
Pour ce qui se passe ensuite, je dirai qu'il n'y a rien d'objectif... plein comme un oeuf partout, trous lissés...
c'est intéressant car je connais plusieurs ninja d'origine (dont le mien!) qui ont des ralentis très aléatoires, chaotiques, voire même "agricoles" alors qu'en charge : tout va bien. Compression entre 10 et 11 sur les 4 pattes...
Alors que les RX que j'ai ont des ralentis dignes de ce nom...
je vais regarder sur la rmt les propriétés d'avance du 1000 RX
dans mon cas, l'idée était de tester ce plateau en complèment d'une paire de webcams, ressorts soupapes renforcés, mikuni rs40... sur mon GG à base de moteur RX. Pour utilisation piste only
vous avez des noms de bouquins du type "le fontionnement moteur pour les nuls"?
ju
MessageSujet: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 11:57
finalement on va faire des motos diesel ,comme ça y aura plus d'avance à l'allumage et on fera avec ! Fuck Fuck
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 12:13
AVEC des WEBCAMS , tu vas nous faire un sacré cinema ... rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241
les ralentis , travelling, fondus etc ... ça va marcher au poil .
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 12:17
TRES FACILE A TESTER TU PRENDS UN DOIGT D ALLUMAGE DE NINJA 750 ET TU VAS ETRE TOUT DE SUITE FIXE rotor +4deg - Page 2 276328 rotor +4deg - Page 2 276328 rotor +4deg - Page 2 276328
SI C EST L AVANCE INITIALE QUI EST EN CAUSE
REGARDE NON SEULEMENT LES PARAMETRES D AVANCE INITIALE ET FINALE
MAIS AUSSI LA PROGRESSIVITE DE LA COURBE D AVANCE LE BOITIER EST SANS DOUTE DIFFERENTE
LA AU MOINS TU FAIS DU VRAI CHANGEMENT MOTEUR
DEMANDES AU FABRICANT DES ARBRES LEUR CALAGE PRECIS
ET L AVANCE QU IL PRECONISE POUR SES ARBRES
IL A FORCEMENT FAIT DES TEST...
LE PLUS SIMPLE A TROUVER C EST UNE RMT QUI DOIT S APPELER
LA PREPARATION DES MOTEURS MOTO
IL Y A DEJA UNE BONNE BASE DE REFLECTION rotor +4deg - Page 2 276328
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 12:21
SI C EST COMME AUDI ET PEUGEOT AUX 24H00 DU MANS ... C EST PAS SI MAL rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241
LE DIESEL C EST PAS QUE LA 504 PIGEOT rotor +4deg - Page 2 615257
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 15:41
ju
ju,
une modif après l'autre c'est la regle
les ressort de soupapes demande l'avis de SS2R je crois que... rotor +4deg - Page 2 679130
40 ça fait pas énorme rotor +4deg - Page 2 896636
pour les ralentis rx et ninja je confirme et il me semble que les plateaux sont identique (il me semble)
par contre pas le meme cdi
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 15:54
ma 900 ninja avait un ralenti parfait!! rotor +4deg - Page 2 276328
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 15:57
a 1200 rmp moi aussi rotor +4deg - Page 2 429241
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 16:02
franchement si c est racing,qu est qu on en a à branler que le ralentis soit stable rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241 rotor +4deg - Page 2 429241 rotor +4deg - Page 2 276328
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 16:37
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime5/3/2010, 18:44
Chef, tu veux faire quoi avec un bouzin dopé comme tu veux le faire ?? rotor +4deg - Page 2 896636 rotor +4deg - Page 2 896636
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime8/3/2010, 09:14
slt pierre w01
c'est pour mon GG
j'attends la RS40 qui est encore aux EU
Puis l'hiver prochain si tout va bien : paire se web cam st2 ou 3+ressorts et essai avec ce plateau... mais comme dit, le mieux serait un banc...
ju
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime8/3/2010, 09:27
OK mais c'est pour faire des courses en classic 17 ou des démos ?
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime8/3/2010, 10:21
j'avais pas pigé la question sorry
juste des démos pour l'instant
pour la suite, on verra quand j'aurai fini mes études (si je les finis un jour inch'allah!)
ju
MessageSujet: Re: rotor +4deg   rotor +4deg - Page 2 Icon_minitime8/3/2010, 11:24
rotor +4deg - Page 2 276328 tu vas faire un "avion", j'espère qu'on aura l'occasion d'être dans la même catégorie rotor +4deg - Page 2 926392 rotor +4deg - Page 2 926392
rotor +4deg
» 2020/12 Modification d’un cône de rotor d’alternateur
» rotor 1135
» rotor d'alternateur
» Extracteur rotor alternateur
» rotor magnetique Z1000 MK2
