Le Deal du moment : -20%
Drone Dji DJI Mini 4K (EU)
239 €
 Z 1000 R CDM KMF
megamax
13 participants
Z 1000 R CDM KMF - Page 2 Empty
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 13:12
elles se font tjrs ??
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 13:23
FAUT DEMANDER CHEZ RAASK IL EST POSSIBLE QU ILS EN AIE ENCORE EN STOCK
J AI ACHETEES CELLES CI NEUVES SUR E BAY
UN MOTOCISTE EN ALLEMAGNE LES AVAIT DEPUIS 20 ANS EN MAGASIN ... Very Happy
IL A FAIT DE LA PLACE albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 13:34
POUR LE MONTAGE DU RADIATEUR A HUILE J AI EU UN PEU DE MAL A RETROUVER LE MONTAGE
POUR QUE TOUT S AJUSTE PARFAITEMENT
J AVAIS CETTE BARRE ROUGE EN ALU TOUJOURS DANS MON STOCK DE TRESORS D EPOQUE GG AVEC UNE PAIRE DE TROUS DONT JE N AVAIS JAMAIS TROUVE ENCORE L UTILISATION
Z 1000 R CDM KMF - Page 2 Hpim6114
C ETAIT TOUT SIMPLEMENT LA FIXATION SUPERIEURE DU RADIATEUR A HUILE
AVEC QUELQUES MODIFS CI DESSOUS
DEMONTAGE DE LA PATTE D ORIGINE KAWA
SUPRESSION DES 2 EXTENSIONS SUPPORT KLAXON (JE N AI PAS ENCORE RETOUVE LEUR MONTAGE POUR L INSTANT )
PLIAGE DU HAUT DE LA PATTE DORIGINE A 90° ENVIRON
ET LE TOUR EST JOUE
LES 2 TROUS SUPERIEURS SE FIXENT SUR LE CADRE AUX EMPLACEMENTS ORIGINAUX
ET LES 2 INFERIEURS RECOIVENT LES FIXATIONS DU RADIATEUR D HUILE
APRES MODIFICATION
VOILA LA PHOTO EN COURS DE VALIDATION DU MONTAGE
Z 1000 R CDM KMF - Page 2 Hpim6113
ET VOILA UNE TETE DE FOURCHE TRES SOLIDEMENT FIXEE A LA MOTO
ET PARFAITEMENT EN PLACE
UNE FOIS TOUT SERRE AVEC DES RONDELLES ET DES NYLSTOP BIEN SUR Very Happy Very Happy
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 22:56
CET APRES MIDI
REMONTAGE STEET LEGAL DE TOUT LE FAISCEAU ELECTRIQUE
MARRE DE TOUTES LES CONNECTION OXYDEES ..JE VOUS RAPELLE 8 ANS A L AIR MARIN C EST PAS TERRIBLE POUR LES CONTACTS
ET LES MODIFS AU NIVEAU DES CLIGNOTANTS ETC...
DU COUP J AI REMONTE CELUI CI COMPLET albino
Z 1000 R CDM KMF - Page 2 Hpim6215
PAS UN FIL MANQUANT TOUT EST CONNECTE
J AI REMONTE DES CLIGNOTANTS A L ARRIERE
ET TOUT FONCTIONNE Cool !!! Cool !!!
PS J AI RECONSTRUIT UN TABLEAU DE BORD
JE VOUS EXPLIQUE APRES
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 23:03
LE TABLEAU DE BORD ETAIT EN RUINE DECOLLE DE PARTOUT ET LA MOITIE DES PATTES DE FIXATION CASSEES A L INTERIEUR
UNE VRAIE MISERE
J AI VAINEMENT ESSAYE DE RETROUVER UN TABLEAU DE BORD DE 1000 R COMME CELUI CI POUR L INSTANT KEDAL A L HORIZON Question
Z 1000 R CDM KMF - Page 2 Hpim3313
PAR CONTRE J AI TROUVE PLUSIEURS TABLEAUX DE BORD DE 750 GPZ ET DE 550 GPZ
QUI LUI RESSEMBLE BEAUCOUP SAUF QUELQUES DETAILS
VOUS POUVEZ JOUER AU JEU DES 7 ERREURS innocent Very Happy Very Happy
Z 1000 R CDM KMF - Page 2 Hpim6218
POUR LES DIFFERENCES LES BRICOLES
LE COMPTEUR MONTE UN TRAIT APRES LE 240 SUR LE 1000R ...
LE COMPTE TOUR COMMENCE SA ZONE ROUGE A 9000 TR/MIN ON S EN FOUT 10 000 C EST BIEN AUSSI
IL Y A UN VOLTMETRE DE TEST DE BATTERIE LA C EST PLUTOT UN BON POINT
CELA SERT TOUJOURS ET C EST EMBARQUE
EN CAS DE DOUTE SUR LA CHARGE DE BATTERIE LE TEST EST IMMEDIAT
LES VOYANTS DE POINT MORT ET DE PHARE SONT PLACES A DES ENDROITS DIFFERENTS
PAS DE PROBLEME J AI BOUGE LES PORTE AMPOULES AUX BONS ENDROITS
EN FAIT COMME LES CONNECTIQUES NE FONT PAS LA MEME LONGUEUR ET QU ELLES SONT TRES LEGEREMENT DIFFERENTES
J AI PIQUE LA MOITIE DU FAISCEAU DU 1000 R QUE J AI GREFFE SUR LE NOUVEAU TABLEAU DE BORD ...
PAS DE PROBLEME TOUT EST VISSE ET LES PORTE AMPOULES SE CHANGENT DE PLACE FACILE
Z 1000 R CDM KMF - Page 2 Hpim3314
LE SEUL TRUC DELICAT C EST LE TABLEAU LCD DU CENTRE QUI A UN FAISCEAU PROPRE A CE MODELE
DEJA PREMIER CONTROLE LA PRISE DU 1000R A 4 FICHES ET CELLES DE LA 550 ET DE LA 750 EN ONT 6
NORMAL
SUR LE LCD YA
LE TEMOIN DE BEQUILLE QUI N EXISTE PAS SUR LE 1000R
LE TEMOIN DE NIVEAU D ELECTROLITE DANS LA BATTERIE
UN RAPPEL DE DEFFAUT LED CLIGNOTANTE ROUGE
ET LES 2 AUTRES FONCTIONS QUE L ON RETROUVE SUR LE 1000 R
L HUILE
ET LA JAUGE A ESSENCE
DEJA LES 2 PRISES NE SONT PAS CABLEES DANS LE MEME ORDRE
JE SORT 4 DES 6 FILS DES COSSES ET JE FAIT CORRESPONDRE LES FONCTIONS
LE 12V ET LA MASSE
C EST PAS LA PENE DE CRAMER UN FAISCEAU TOUT NEUF
BRANCHEMENT
BONNE SURPRISE LA JAUGE A ESSENCE FONCTIONNE PARFAITEMENT
SANS DOUTE LE PLUS DELICAT CAR PROPORTIONNEL albino albino albino
ENSUITE C EST UN VRAI SAPIN DE NOEL
LES TEMOINS DE BATTERIE ET DE BEQUILLE CLIGNOTTENT A QUI MIEUX MIEUX
NORMAL CAR COMME ILS NE SONT PAS RACCORDES IL DONNENT L ALERTE
CELA RISQUE D ETRE VITE AGACANT
JE FAIS UNE TRIPLETTE AVEC LES COSSES MADE IN JAPAN DE CHEZ ZONE INTERDITE
ET JE RENVOIE UN 12V PERMANENT SUR LES 2 CLIGNOTEURS QUI SE CALMENT IMMEDIATEMENT
VOILA C EST FAIT ...
POUR LE TEMOIN D HUILE TOUT VA BIEN ... POUR L INSTANT
IL CLIGNOTTE 3 SECONDES A LA MISE SOUS TENSION
ET IL EST ETEINT A L ARRET cafume1
JUSQU AU MOMENT OU JE DEMARRE LA MOTO
ET LA PRESQUE IMMEDIATEMENT IL SE MET AU ROUGE CLIGNOTANT
UN DOUTE D UNE SECONDE .... PROBLEME DE PRESSION D HUILE pale pale pale
ETONNANT TOUT ALLAIT PARFAITEMENT JUSQUE LA ...
NON JUSTE FANTAISIE KAWASAKISTE tongue tongue
D UNE MOTO A L AUTRE ON A SOIT
UN TEMOIN DE PRESSION D HUILE SUR LES 1000 J ET 1000R
ET UN TEMOIN DE NIVEAU D HUILE SUR LE 550 GPZ H1
ET CELA FONCTIONNE ... A L ENVERS
POUR LA PRESSION D HUILE CLASSIQUE C EST PAS DE CONTACT TANT QUE LE MOTEUR EST ARRETE ET DES QUE LA PRESSION MONTE LE 12V EST ENVOYE AU TEMOIN ET IL S ETEINT
POUR LE NIVEAU D HUILE C EST L INVERSE LE CONTACT EST OUVERT TANT QU IL Y A DE L HUILE DANS LE CARTER MAIS SI LE NIVEAU EST TROP BAS LE CONTACT SE FERME ET ENVOIE LE 12V AU TEMOIN ET IL S ALLUME
DAMNED Question Question Question
Y AURAIS BIEN UNE BIDOUILLE AVEC UN MICRO RELAI A CONTACT INVERSE POUR REMETTRE
LA FONCTION A L ENDROIT
MAIS J AI UNE AUTRE IDEE Very Happy
APRES CONSULTATION DES SCHEMAS ELECTRIQUES IL SEMBLERAIS QUE LE Z 750 L4 POSSEDE LUI UN TEMOIN DE PRESSION D HUILE COMME LE 1000 R
DONC NORMALEMENT EN REPIQUANT LA PLATINE LCD DU 750 TOUT DEVRAIT RENTRER DANS L ORDRE
YAPUKA
EN ATTENDANT SUITE A CETTE PRISE DE TETE ELECTRIQUE Suspect
J AI ETE FAIRE UN TOUR POUR
VERIFIER QUE LA CARBURATION A BON REGIME ETAIT PARFAITE
SORTIE DE POT COULEUR CARAMEL
ET QUAND TOURNE LA POIGNEE
LE VOYANT D HUILE A BEAU CLIGNOTER COMME UN DEBILE
ON S EN FOUT
ON REGARDE LA PROCHAINE COURBE POUR PAS SE SORTIR
CAR CELA DEBOULE ASSEZ VITE MA FOIS banana1 banana1 banana1
ET J AI ENCORE LES FREINS D ORGINE affraid affraid affraid
VOILA POUR CET APRES MIDI ...
A PART CETTE TOUTE PETITE CONNERIE TOUT FONCTIONNE PARFAITEMENT
A SI J OUBLIAIS J AI FAIT UN PEU DE POLY EN RENTRANT innocent
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 23:18
y en a pas mal mais logiquement, ça se branche! Very Happy sauf pour le témoin de jus et la béquille!!
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 23:30
t as trouve pour faire marcher les cristaux liquides
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 23:41
J Y ARRIVE ... Very Happy Very Happy
J ARRIVE PAS A TAPER PLUS VITE QUE VOS QUESTIONS casse casse casse
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 23:50
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime5/8/2008, 23:58
Very Happy hate de lire la suite .... albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 00:19
POUR LE POLY VOUS RECONNAITREZ SANS PEINE LES PIECES innocent innocent
Z 1000 R CDM KMF - Page 2 Hpim6220
PETITS ENFORTS AUX POINTS STRATEGIQUES DE FIXATION DES DZUS ET SUR LES CARRES DE FIXATION DU SABOT DE 1135 R
ROVING FIN 160 GRAMMES EN 3 COUCHES CROISEES
BEAUCOUP MIEUX QUE L ORIGINE Very Happy Very Happy
ET ENSUITE DEMAIN UN COUP DE NOIR SATINE A L INTERIEUR DES CARENAGES
CE SERA TOUT DE MEME PLUS SOIGNE albino albino
WALA C EST FAIT
Z 1000 R CDM KMF - Page 2 Hpim6221
Sympa cette histoire Yves albino (bluffant le coup du carnet d'entretien w01 )
Ah oui... j'adore la finesse typique de Godier Genoud: innocent innocent innocent
il manque plus que le petit tube à bulle et on l'a notre niveau à bulle de chantier !!!! Aaaaahhh sacré GG!!!! casse casse
casse casse casse Very Happy Very Happy Very Happy Evil or Very Mad Evil or Very Mad
bub'
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 00:50
vous lui avez fait boire un truc ou bien ???
huuuh1 huuuh1 huuuh1
enervé comme un chat maigre, voilà ce que je dis!!! Very Happy Very Happy Very Happy
c'est le kit 1135 qui te fait ça ???
tu pars en vacances avec ???
Ou alors, t'as décidé d'y aller dans l'ordre ....Une après l'autre et faut se mettre à jour avant ..........................................................................................................
Des fois qu'y en ai un qui débarque evec des bouts de pièce partout innocent innocent
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 00:56
NAN CA FAIT SEULEMENT 2 JOURS QUE JE SUIS EN WACANCES Very Happy
ALORS JE BRICOLE PEINARD innocent innocent
BON ET JE VOUS PASSE LES TRAVAUX DE BATIMENTS ENTRE 2 .... Sad
BON C EST PAS LE TOUT
AU LIT DEMAIN
YA UNE AUTRE JOURNEE DE VACANCES ....
A ATTAQUER DE BONNE HEURE cafume1 cafume1
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 10:11
Chouette histoire ...
vite, la suite ... Very Happy Very Happy Very Happy
Merci Merci
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 12:37
Tu es sur que tu es en vacances innocent
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 20:20
J'suis tout chose à l'idée de ce qu'il va nous commanter sur et surtout dans le moulbif.... banana1
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 20:51
pas sur qu'il ait prévu de l'ouvrir w01
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime6/8/2008, 22:17
POUR LINSTANT YA TOUT CE QU IL FAUT POUR ROULER SUR LA ROUTE ... Cool !!! Cool !!!
UN 4/1 QUI RESPIRE CORRECTEMENT SANS TERRORISER LES POPULATIONS
UNE BEAU MOTEUR AVEC UN KIT WISECO 1135 CC TOUT NEUF
DES ARBRES A CAMES DE 1000R BIEN CALES
UNE RAMPE DE CARBU DE 1000 R BIEN REGLEE AVEC DES GICLEURS PRINCIPAUX EN 150
ET DES KN KOREENS CONIQUES
RIEN DE TRES EXTRAORDINAIRE
MAIS ELLE TOURNE COMME UNE COMTOISE DU HAUT DOUBS albino albino
PAS UNE GOUTE D HUILE A TERRE
AUCUNE RAISON VALABLE POUR OUVRIR LE MOTEUR
JE SAIS COMMENT C EST FAIT DEDANS Sad
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime7/8/2008, 00:38
De bonnes vacances quoi .... casse casse casse casse casse casse albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime16/8/2008, 18:30
Z 1000 R CDM KMF - Page 2 Hpim6224
CELA COMMENCE A RESSEMBLER A QUELQUE CHOSE tof01
QUELQUES DECO A VENIR ET CE SERA PRESENTABLE
Z 1000 R CDM KMF - Page 2 Hpim6225
UN PETIT CLIN DOEUIL w01
Z 1000 R CDM KMF - Page 2 Hpim6226
LA SUITE A LA RENTREE .... innocent innocent innocent
Z 1000 R CDM KMF - Page 2 Hpim6227
CELA DEVIENT INDISPENSABLE VUE LA SANTE DU MOTEUR ... casse casse casse
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime16/8/2008, 21:17
albino albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime17/8/2008, 00:46
pastis 51... innocent respect! albino casse casse casse casse
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime18/8/2008, 13:40
albino albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF - Page 2 Icon_minitime18/8/2008, 22:58
normal pour un jaune Very Happy
Z 1000 R CDM KMF
» GG 1000 garde républicaine
» Pompe à huile 1000 J / 1000 R
» rapport volumetrique 1000 J / 1000 r
» 1000 HRC
FORUM DES MOTOS SPÉCIALES :: MOTOS SPECIALES :: MOTOS GODIER GENOUD-
