599 €
 Z 1000 R CDM KMF
megamax
13 participants
Z 1000 R CDM KMF Empty
MessageSujet: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 20:21
TRADUCTION
Z 1000 R2 1983 AVEC LE KIT CHAMPIONNE DU MONDE SIGLEE KMF HABILLEE PAR GG
PAS SIMPLE DE VENDRE LES FIN DE SERIE A L EPOQUE
FAUT APATER LE CLIENT
J AI RECUPERE CETTE MOTO LE LONG DE LA MER OU ELLE EST RESTEE 8 ANS SANS TOURNER
DANS LE PAS DE CALAIS
APRES UNE TRES GROSSE REVISION
DEMONTAGE DE TOUS LES CARTER ET NETTOYAGE INTERIEUR DE FOND EN COMBLE
REMPLACEMENT DE TOUS LES JOINTS
JEUX AU PASTILLES
TENSION DE LA CHAINE DE DISTIBUTION
DEMONTAGE DE L EMBRAYAGE COLLE
REMPACEMENT DE 2 DISQUES LISSES VOILES
REMPLACEMENT DES RESSORTS D ORIGINE CALES PAR 2 RONDELLES
PAR DES RESSORTS RACING
ET REMONTAGE D UNE RONDELLE DE CALAGE
JE SUIS PAS ENCORE PLEINEMENT SATISFAIT DE L EMBRAYAGE
IL ENTRAINE UN POIL A FROID CE QUI REND LE POINT MORT DIFFICILE A TROUVER
REGLAGE MOTEUR ET REMPLACEMENT D UNE BOBINE
DES BOUGIES ET ANTIPARASITES NGK
DEMONTAGE DE LA RAMPE DE 1000 J PASSAGE AUX ULTRA SONS
ET TENTATIVE DE REGLAGE INFRUCTUEUSE
AVEC LES FILTRES CONIQUES ET LE KIT WISECO 1135 ELLE MANQUE D ESSENCE ET BRIDE A L ADMISION
RECUPERATION D UNE RAMPE DE 1000 R EN 34 NETTOYAGE AUX ULTRA SONS ET REGLAGES
MONTAGE DE GICLEURS PRINCIPAUX EN 150
ET VIS DE RICHESSE DESSEREES DE 1TOUR 3/4
NIVEAUX DE CUVE + 1MM
ET AIGUILLES AU 3EME CRAN
ELLE FONCTIONNE BIEN
RALENTI A 800 TR/MIN BIEN STABLE MEME A CHAUD EN VILLE AU FEU ROUGE
AUCUN TROU A L ACCELERATION JUSQUAU PROCHAIN FEU
REMPLACEMENT DE LA FOURCHE DONT LES TUBES SONT TROP PIQUES POUR ETRE RECUPERABLES
UN PIEGE LA FOURCHE DE 1000 J2 N EST PAS TOTALEMENT IDENTIQUE A LA 1000 R
JE LE SAVAIS MAIS CELA CE JOUE A 3 MM AU NIVEAU DE LA FIXATION DES
PATTES D ETRIERS DE FREINS SINON LES ETRIERS FROTTENT SUR LES DISQUES Razz
DONC MIXAGE ENTRE LE FOURCHE DE 1000 R ET CELLE DE J2
ATTENTION FAUT BIEN SUIVRE
MONTAGE DES TUBES ET DE TOUTE L HYDRAULIQUE DU 1000 J2 DANS LES FOURREAUX DU 1000R
SANS PROBLEME
REMPLACEMENT DES JOINTS ET DES BAGUES DE GUIDAGE PAR LA MEME OCCASION
ATTENTION REMONTAGE DE RESSORTS DU 1000R QUI SONT PLUS LONGS ET PLUS DURS
ET DES BOUCHONS DU 1000 J QUI SONT PLUS LONGS
CE QUI DONNE UNE PRECONTRAINTE PLUS IMPORTANTE AUX RESSORTS QUI EVITE LES CALES ET CONSERVE UNE PARFAITE FLEXIBILITE
LA FOURCHE EST TRANSFIGUREE ET PAS BESOIN DES RALONGES GG POUR L INSTANT
AU NIVEAU AMORTISSEMENT C EST TOUT BON
REMPLISSAGE AVEC 50% DE 15W ET 50% DE 20 W 315 CM3
AJUSTE A 110 MM DU HAUT DES TUBES SANS RESSORTS
ENFIN FAUT DIRE QU AVEC LE FREINAGE D ORIGINE JE NE LA FAIT PAS TROP SOUFFRIR ... innocent
POUR LE FREINAGE JUSTEMENT
DEMONTAGE DES 3 ETRIERS NETTOYAGE ET GRAISSAGE DES JOINTS
REMPLACEMENT D UN PISTON ARRIERE PIQUE
DEMONTAGE COMPLET DU MAITRE CYLINDRE AVANT NETTOYAGE AUX ULTRA SONS
REMPLISSAGE AVANT REMONTAGE ET PURGE COMPLETE
REMPACEMENT DE 2 VIS DE PURGE ABIMEES
REMONTAGE DES BOUCHONS D ORIGINE
DEMONTAGE COMPLET DES CARENAGES ET REMONTAGE AVEC TOUTES LES BONNES PIECES
PROVENANT DE 3 MOTOS DIFFERENTES
J AI ENFIN TROUVE LE MONTAGE COMPLET D UN CARENAGE KMF
AVEC TOUTES LES VIS QUI VONT DANS TOUS LES TROUS
LES REGALGES DE PHARES LES HAUTEURS POUR QUE TOUT S AJUSTE PARFAITEMENT
LE MONTAGE COMPLET DU RADIATEUR D HUILE AVEC SON SUPPORT HAUT ET BAS
JUSTE UN DETAIL QU IL RESTE A VOIR LE POSITIONNEMENT DES KLAXON ...
ENFIN AVEC LE 4/1 SEBRING C EST PAS INDISPENSABLE POUR L INSTANT
A SUIVRE EN PHOTOS ...
JE VAIS MANGER ...
megamax
megamax
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 20:34
albino albino de la bonne ouvrage!! et bon appetit !
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 20:48
Super interaissant; surtout le passage des ressort de 1000R dans du J
La je ne regrette pas de tout garder car j'ai une fourche de 1000R piques , je pense que je vais faire le test ... en plus ca coute rien ca tombe bien car j'ai pete la voiture ..... Et le budget moto repart au dessous de zero.
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 20:50
Rien compris Rien compris tu parles d un 1000 R qui est où ??? huuuh1 Very Happy
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 20:57
JE PEUT ALLER MANGER QUAND MEME .... CA ARRIVE LES PHOTOS ....
FAUT PAS POUSSER ON EST PAS AU BAGNE Sad Sad
J EN SUIS JUSTE AU DESCRIPTIF
LE RESTE CA VIENT ....
HAAA LALA :l'boulot :l'boulot :l'boulot
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 20:59
Very Happy silent Idea
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 21:18
LE POINT DE DEPART ....
J ENCHERI SUR E BAY IL Y A UN AN POUR UN LIVRET DE L UTILISATEUR DE 1000 R POUR AVOIR LE
SCHEMA ELECTRIQUE POUR REPARER UNE MOTO D UN COPAIN UNE ELR 1000 R1 VERTE
JIIIIIIIMMMMM albino albino albino
JE SUIS UN PEU DECU CAR JE RECOIT UN MANUEL DE 1000 R2 ELLE EST TRES LEGEREMENT DIFFERENTE
Z 1000 R CDM KMF Scan0010
LE TAMPON DU CONCESSIONNAIRE EST LILLE MOTOS DUCROO
ET LES RDV DES PREMIERES REVISIONS SONT NOTES .....
FIN DE L EPISODE
AU PRINTEMPS JE TOMBE SUR UNE EPAVE DE 1000 R CAR IL N Y A PAS D AUTRE MOT VU L ETAT DE LA MACHINE
QUELQUES AUTOCOLLANTS ATTIRENT TOUT DE MEME MON ATTENTION
EN VOICI LES PREMIERES PHOTOS
Z 1000 R CDM KMF Hpim2311
Z 1000 R CDM KMF Hpim2410
Z 1000 R CDM KMF Hpim2411
Z 1000 R CDM KMF Hpim3110
LA VOILA EXTIRPEE DU SOUK
FAUT EN AVOIR ENVIE ....
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 21:29
APRES ANALYSE DES N° DE MOTEUR ET DE CADRE
IL S AGIT BIEN COMME JE L AVAIS VU AU PREMIER COUP D OEUIL D UNE BASE 1000 R
AMORTOS SELLE MOTEUR CARTERS NOIR TABLEAU DE BORD ETC ...
MAIS C EST UN 1000 R 2 DE 1983
UNE PETITE PLAQUE RIVEE SUR LE GARDE BOUE AVANT ATTIRE MON ATTENTION
Z 1000 R CDM KMF Hpim6210
JE VOUS LE DONNE EN MILLE
JE FONCE RECHERCHER MON PETIT BOUQUIN
Z 1000 R CDM KMF Scan0011
C EST LE MANUEL D ENTRETIEN DE LA MOTO LE N° DE CADRE ET DE MOTEUR SONT NOTES DEDANS ...
J AI ACHETE IL Y A UN AN LE MANUEL AU PREMIER PROPRIETAIRE QUI L AVAIT CONSERVE DEPUIS
LA VENTE DE SA MOTO LE 13/10 1995
DATE QUI FIGURE SUR LA CARTE GRISE
LA MOTO N A CONNU QUE 2 PROPRIETAIRES
AMMUSANT NON ????
LES DEUX PREMIERES PIECES DU PUZZLE SONT REUNIES ET C EST DE BON AUGURE
MALHEUREUSEMENT L HISTOIRE EST TRISTE CAR SON SECOND PROPRIETAIRE EST DECEDE ACCIDENTELLEMENT EN 2000
ET CE SONT SES PARENTS QUI SE SONT RESOLU A VENDRE CETTE MOTOS QUI ETAIT DANS LE GARAGE DEPUIS CE TEMPS LA AYANT FAIT LEUR DEUIL
JE NE L AI SU QU APRES AVOIR TENTE DE REPRENDRE CONTACT SUITE A MES PREMIERES TROUVAILLES
DONC JE NE SAURAIS QU UNE PARTIE DE L HISTOIRE DE CETTE MOTO MAIS C EST DEJA PAS MAL
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 21:42
Ha!!! y a ' une base albino comme y diro ch'tisote
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 21:43
cette moto est pour toi, peux pas mieux dire w01
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 21:46
excellent!! albino albino
c toi qui m'avais acheté le manuel???
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 21:48
De toutes manières il ne la vend pas .....!
Merci yves pour ce post ... Bien diné??? cafume1 casse casse casse w01
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:06
NON M AIS C ETAIT JUSTE POUR LE CLIN D OEUIL CAR LA 1000 R1 ELR DE MON COPAIN ETAIT VERTE
COMME TU SEMBLE LES PREFERER innocent innocent innocent innocent
POUR LA MIENNE ELLE EST PLUTOT ......COMME LA COUVERTURE DU MANUEL ... JAUNE
ENFIN PAS NIMPORTE QUEL JAUNE
LE GARS PREMIER PROPRIETAIRE ETAIT UN FAN DE GG
ET L AVAIT FAIT REPEINDRE PAR UN CARROSSIER COMME CELLES CI albino albino albino
EN 1984 POUR L ANNIVERSAIRE DES 10 ANS DE LA VICTOIRE AU BOL bounce bounce bounce bounce
Z 1000 R CDM KMF Gg_cou10
CAR POUR CEUX QUI ONT LA MEMOIRE COURTE UNE GG A L ORIGINE
C EST .....JAUNE casse casse
ET RE PAF ...
Z 1000 R CDM KMF Gg_egl10
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:12
ou bleu casse casse casse
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:25
Jim... ????? Hey Jim !!!!!! J'aime pas le vert mais je trouve le jaune encore plus dégeulasse ! Sad w01
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:28
sympa comme tout cette histoire albino albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:38
j'allais baver chez Ducroo quand j'avais 15-16 piges
c'est aujourdhui un simple concessionnaire multi-marques
chouette histoire Yves w01
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:40
POUR LA SUITE DES INVESTIGATION
PREMIERE SURPRISE AU DEMONTAGE
LE CARENAGE EST DIFFERENT DE CEUX QUE J AVAIS L HABITUDE DE VOIR SUR TOUTES LES GG
QUE J AI EU ENTRE LES MAINS
DEJA LE SIGLE SUR LE TABLEAU DE BORD N EST PAS L HABITUELLE DOUBLE LETTRE GG
MAIS
KMF QUI VEUT DIRE BIEN SUR KAWASAKI MOTOR FRANCE
Z 1000 R CDM KMF Hpim6010
ENSUITE POUR LES ATTACHES DE CARENAGES ELLES SONT PARTICULIEREMENT BIEN FAITES
ET PLEIN DE DETAILS FONT QUE C EST TOUT A FAIT RIGIDE
LES PHARES SONT REGLABLES TRES FACILEMENT
LA BULLE FUMEE EST USINEE TRES PROPREMENT AVEC DES OBLONGS POUR LA REGLER A CHAQUE FIXATION ET PAS DE VULGAIRES TROUS ....NOTA C EST LA BULLE D ORIGINE QUI EST ENCORE SUR LA MOTO MALHEUREUSEMENT LE RETRO GAUCHE EST PASSE A TRAVERS LORS DU TRANSPORT DANS LE CAMION tongue tongue tongue
LE TETE DE FOURCHE EST TRES SOLIDEMENT FIXE ET NE VIBRE PAS MEME QUAND LE BAS N EST PAS MONTE
ET POUR LE BAS JUSTEMENT IL EST FIXE AVEC 4 DZUS RAPIDE PAR L INTERIEUR DU CARENAGE
ET 2 POINTS DE FIXATION SUR LES GOUJONS DE CULASSE MOTEUR
AVEC DES PIECES TRES SPECIFIQUES QUE J AVAIS DANS MON STOCK DE PIECES GG DEPUIS 15ANS
Z 1000 R CDM KMF Hpim6110
LES DECOUPES DU BAS DE CARENAGE SONT DIFFERENTES DE CELLES HABITUELLE
ET LES ENCOCHES DE POTS CORRESPONDENT AUX 2X2/1 D ORIGINE 1000 R
AVEC LESQUELS LA MOTO ETAIT LIVREE
Z 1000 R CDM KMF Hpim3310
Z 1000 R CDM KMF Hpim3312
CETTE MOTO A ETE COMMANDEE A L ORIGINE PAR SON PROPRIETAIRE
AVEC LE POT QU ELLE A MAINTENANT
UN SEBRING D EPOQUE HOMOLOGUE ENFIN PRESQUE ...AVEC CARTOUCHE ALU
ELLE ETAIT BLANCHE AVEC LES BANDES BLEU MARINE ET ROUGE FILET OR
ET LE CARENAGE ETAIT BLANC AVEC LES DECO DANS LES MEMES COULEURS
STYLE GG
CELA DEVAIT DONNER UN SUPERBE ENSEMBLE
LES CLIGNOTANTS ETAIENT DES MODELES CITROEN DIANE OU ALPINE BERLINETTE POUR FAIRE PLUS CHIC ... innocent
Z 1000 R CDM KMF Hpim6011
LES RETROS ENGELMANN ONT ETES REMPLACES A LA PREMIERE REVISION PAR DES VITALONI NOIR CAR IL NE VOYAIT QUE SES EPAULES ET IL TROUVAIT CELA DANGEREUX EN VILLE
Z 1000 R CDM KMF Hpim3311
LE PROPRIO AVAIT AUSSI DEMANDE QUE L ON REMPLACE LA BARRE DE MAINTIENT NOIRE MAT PAR UNE VERSION CHROMEE DE 1000 J QU IL TROUVAIT PLUS JOLIE
LE GARDE BOUE AVANT A LUI AUSSI ETE REMPLACE PAR UN MODELE DE 1100 GPZX BLANC EN PLASTIQUE
QU IL TROUVAIT BEIN MIEUX QUE LE MODELE EN FER ANGULEUX D ORIGINE
AU MOINS LE GARS SAVAIT CE QU IL VOULAIT ET AVAIT PLUTOT BON GOUT
VOILA DONC L ETAT DE LIVRAISON ORIGINAL DE CETTE MACHINE
AUX DIRES DE SON PREMIER PROPRIETAIRE
C EST TOUT A FAIT CE QUE J AI RETROUVE SUR LA MOTO
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:52
belle histoire albino albino
tu vas la laisser jaune?
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 22:58
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 23:00
QUI SAIT ??? POUR L INSTANT JE SUIS DANS L ELECTRICITE ET QUELQUES ACCESSOIRES INDISPENSABLES ....
LE COSMETIQUE C EST EN DERNIER ... ET YA ENCORE BEAUCOUP DE BOULOT DESSUS
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 23:34
CET APRES MIDI innocent
AVANT COTE DROIT
Z 1000 R CDM KMF Hpim6211
APRES
Z 1000 R CDM KMF Hpim6212
AVANT COTE GAUCHE
Z 1000 R CDM KMF Hpim6213
APRES
Z 1000 R CDM KMF Hpim6214
J AI JAMAIS PU CONDUIRE UNE MOTO AVEC LES PATTES EN AVANT
JE NE SAIT PAS COMMENT VOUS FAITES SUR LES 1135 GG AVEC LES COMMANDES D ORIGINE
LA POSITION EST BIEN MEILLEURE COMME CELA POUR MOI
MERCI MR RAASK albino albino
POUR LES AUTOCOLLANTS DONT JE VOUS PARLAIS PLUS HAUT
ET QUI AVAIENT ATTIRE MON ATTENTION QUAND J AVAIS FAIT LE PREMIER TOUR DE LA MOTO
JE VOUS CONFIRME YA PAS QUE LES AUTOCOLLANTS LE RESTE DU KIT EST DANS LE MOTEUR w01
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime4/8/2008, 23:59
Magique ... albino
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime5/8/2008, 13:08
albino albino
jolie histoire , vivement l'episode suivant ! Very Happy
MessageSujet: Re: Z 1000 R CDM KMF   Z 1000 R CDM KMF Icon_minitime5/8/2008, 13:11
au top les commandes!! albino albino
Z 1000 R CDM KMF
» GG 1000 garde républicaine
» Pompe à huile 1000 J / 1000 R
» rapport volumetrique 1000 J / 1000 r
» 1000 HRC
FORUM DES MOTOS SPÉCIALES :: MOTOS SPECIALES :: MOTOS GODIER GENOUD-
