C EST UNE ERREUR POUR LES DIMENTIONS
LA BATTERIE D ORIGINE DU ZX 1100 A1 KAWA FAIT LARGEUR 100 MM LONGUEUR 175 MM ET HAUTEUR 155 MM
C EST UNE CB 16 LB ET ELLE FAIT BIEN 16 AMP
PAR CONTRE SI TA MACHINE N EST PAS EQUIPEE DE L INJECTION UNE BATTERIE DE 14 AMP EST TOUT A FAIT SUFFISANTE
UNE YB14LA2 QUI FAIT 91X 135 H 166 CELA DEVRAIT RENTRER DANS TON SUPPORT
ET ON NE PARLE QUE DE BATTERIES CLASSIQUES AU PLOMB
TU VA TROUVER DES BATTERIE BEAUCOUP PLUS PUISSANTES AVEC DES ENCOMBREMENTS PLUS FAIBLES
ET UN POIDS PLUME AVEC LES NOUVELLES TECHNOLOGIES PAR CONTRE LE PRIX EST IMPORTANT
