TOUT DEPENDS CE QUE TU SOUHAITES FAIRE
DU PETIT BUDGET
TU PRENDS DU FIL DE BOUGIE HT AU METRE EN DIAMETRE 7 OU 8 SUIVANT LES CONNECTIQUES SUR TES BOBINES
AU FOURNISSEUR D EQUIPEMENT AUTOMOBILE A COTE DE CHEZ TOI
ET TU ADAPTES LES CAPUCHONS DE BOUGIE NGK STANDARD C EST QUELQUES EUROS LE METRE ...ET EN GENERAL EN NOIR AVEC AME EN CUIVRE CELA FONCTIONNE TRES BIEN SANS SOUCIS
INCONVENIENT C EST PAS TRES SOUPLE ET IL NE FAUT EN AUCUN CAS QUE TU TOUCHES LE MOTEUR SINON CELA FOND
DU PUR EFFICACE ET ECONOMIQUE
TU ACHETE UN FAISCEAU DE BAGNOLE AMERICAINE V8 TU VAS TROUVER DES ENSEMBLES COMPLETS DE TOUTES LES COULEURS
QUE TU SOUHAITES EN BLEU JAUNE ROUGE ETC... AVEC DES LONGUEURS CONSEQUENTES POUR UN PRIX IMBATABLE
TU LES MONTES SUR TES BOBINES ATTENTION C EST SOUVENT DU DIAMETRE 8 ET PARFOIS 9
C EST DU SILICONE TRES SOUPLE CERTAINS ONT MEME DES AMES EN CARBONE
CELA NE PEUT PAS FONDRE SUR LE MOTEUR A PART SUR LES POTS ... FAUT PAS EXAGERER TOUT DE MEME
INCONVENIENT TU AS SOUVENT QUE DES CAPUCHONS DE BOUGIE DROITS ET ILS SONT TRES DIFFICILES
A DEMONTER CAR ILS FONT VENTOUSE
AVANTAGE TU PEUX ROULER SOUS LE DELUGE PLUS ETANCHE C EST PAS POSSIBLE
DU LOOK AVEC COULEUR ET TOUCHE RACING
LES FAMEUX NGK QUI EXISTENT EN DROIT OU COUDES
ATTENTION AUX REFERENCES EN FONCTION DES TAILLES DE BOUGIES
C EST LE TOP DE LA QUALITE POUR MOTO
MAIS CELA COUTE UN OEUIL
MAIS C EST LE TOP DE LA QUALITE
APRES IL Y A LA FRIME HORS DE PRIX NON JUSTIFIEE POUR MOI
LE NOLOGY A PART EN DRAG AVEC DES ALLUMAGES A PLUS DE 50 000 V OU DES MAGNETO
C EST DU GASPILLAGE POUR L UTILISATION CLASSIQUE
IL N EN RESTE PAS MOINS VRAI QUE C EST DU BON MATERIEL MAIS INUTILE DANS TON CAS
AUTRE PROBLEME LES ADAPTATION DES CONNECTIQUES SONT EXTREMEMENT DELICATES
ET DEMANDE UN MATERIEL DE SERTISSAGE PARTICULIER SI ON VEUT FAIRE CELA CORRECTEMENT
ENFIN POUR LES LONGUEURS IL FAUT SAVOIR QUE LES ELECTRONS SE PROPAGENT A LA VITESSE DE LA LUMIERE
ALORS SUR UNE MOTO ... SI TU AS 0.50M OU 1M DE CABLE ... YA PAS DE SOUCIS
TU PEUX MONTER LES BOBINES DANS LE DOSSERET DE SELLE SI TU VEUX TU N AURAS PAS A CORRIGIER L AVANCE A L ALLUMAGE
