| Suzuki gs1000r xr69 endurance replica | |
+32mika46 bruno caffy arnaud L@rgal speed R1 onze35 chris59 Franky chef Pat750 Raoul Volfoni windle Kerax j-c franck ag2 macpepr phiphi baba41 ultraviolet91 tidji la tige rogerboldor Lemarquis THIERRY67 STOK51 Pascal94 Titane nini72 Pierre japy JackCélaire 36 participants |
| Sujet: Suzuki gs1000r xr69 endurance replica 31/7/2013, 23:47 | |
| We are building a suzuki xr69 endurance replica (Japan or france version), does anybody have the orginal fairing (tete de fourche)??? Don't be shy to help us out We are going to make the frame by ourself with bronze welding (sorry for my poor English) Parts that we already have are: Dymag wheels Lockheed brakes Brembo rear brake Rg500 front fork Dresda rear fork Keihin cr33 Gs1000 engine And other parts |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/8/2013, 00:20 | |
| Yoshy fairing on ebay.de http://www.ebay.de/sch/i.html?_trksid=p5197.m570.l1313.TR0.TRC0.Xyoshimura+gs&_nkw=yoshimura+gs&_sacat=0&_from=R40 nice project |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/8/2013, 07:42 | |
| Thanks, I know that fairing, but it is not a good replica
It is a good try from these guys but it is nut the same |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/8/2013, 22:50 | |
| Sinon y as celle la Mais c est pas une vraie Japy |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 2/8/2013, 19:31 | |
| Good evening,
You may follow the original manufacturer :
http://www.harris-performance.com/acatalog/F1.pdf
price depends on the model you like to select
Fibreglass Suzuki XR69 style race full fairing with Dzus fasteners, plain front : £250 Fibreglass Suzuki XR69 style race full fairing with Dzus fasteners, moulded front to accept twin headlight : £290 Fibreglass Suzuki XR69 style Endurance racing top half fairing, with plain front : £160 Fibreglass Suzuki XR69 style Endurance racing top half fairing, moulded front to accept twin headlight : £200
If you are interested, we produce a Poly/Kevlar made of Jersey tissue instead of the classical sauerkraut fabrication. |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 6/8/2013, 09:12 | |
| Ok, thanks guys! Tonight I will place some fotos of the progress sofar
What do you think: chrome molybydeen or reynolds 631 or normal steal we want to do the bronce welding
What are the best options? |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 18/8/2013, 19:59 | |
| - Christian1991 a écrit:
- Ok, thanks guys! Tonight I will place some fotos of the progress sofar
What are the best options? bronze welding was a good and used method to build racing chassis. However, with the new tires and new performance engines... users should carrefully keep en eye on racing condition. Most of frame builders does NOT want to produce this kind of frames, exception made for Classic or replicates motorcycle. The last edition, whelded by spot bronze welding, the XR69 used by a well know English pilot, during the last TT Classic, shows how this (beautifull) assembly may be dangerous on today's performance. this is my 2 cents opinion, I use to share with myself. hope this will help you in your quest. But please contact today's manufacturers to get their opinion. Reynold 631 tig welded seems to be their last choice. |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/10/2013, 22:34 | |
| Here are some purchased items that we already have This is the rg500 front fork wits 18 inch dymags. Here I am sweep up the gs1000 a little bit:cpasmoi: Dresda swingarm and 18 inch dymag with brembo p08 caliper And last but not least.... al the tubings and steel plates for the frame:banane1: |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/10/2013, 22:38 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/10/2013, 22:43 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 17/10/2013, 16:48 | |
| We have a nice scitsu rev counter This winter we are going to build the frame... we are very excited:cpasmoi: |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 24/10/2013, 13:51 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 29/10/2013, 23:00 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 29/10/2013, 23:02 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 06:54 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 11:56 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 12:03 | |
| The weight isn ´ t the goal, but the cooling |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 12:17 | |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 22:34 | |
| Bonsoir Titane
C est pour mieux refroidir les perçages au niveau du puits de bougie ??? et pourquoi certains trous sur les ailettes ne débouchent pas ????? Japy |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 23:06 | |
| - japy a écrit:
- Bonsoir Titane
C est pour mieux refroidir les perçages au niveau du puits de bougie ??? et pourquoi certains trous sur les ailettes ne débouchent pas ????? Japy Les amorces de perçage autour des filetages de bougies et de certains plans de joint sont là pour augmenter la surface de matière en contact avec l'air et donc, effectivement, de mieux refroidir. Les amorces de perçages non débouchant dans les ailettes sont ... en face des conduits d'admission ! Percer débouchant à cet endroit causerait quelques problèmes ............... JM |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 30/10/2013, 23:57 | |
| - Titane a écrit:
- japy a écrit:
- Bonsoir Titane
C est pour mieux refroidir les perçages au niveau du puits de bougie ??? et pourquoi certains trous sur les ailettes ne débouchent pas ????? Japy Les amorces de perçage autour des filetages de bougies et de certains plans de joint sont là pour augmenter la surface de matière en contact avec l'air et donc, effectivement, de mieux refroidir. Les amorces de perçages non débouchant dans les ailettes sont ... en face des conduits d'admission ! Percer débouchant à cet endroit causerait quelques problèmes ............... JM Pas assez réfléchie, c est effectivement un gros problème:Merci: Japy |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 31/10/2013, 20:39 | |
Pascal94
| Sujet: Re: Suzuki gs1000r xr69 endurance replica 1/11/2013, 14:38 | |
| Bonjour Un des secrets A+ Pascal |
| Sujet: Re: Suzuki gs1000r xr69 endurance replica | |
